tps problem
i have a 93 cx and i have an lsvtec in there.....now my question is y does the car run fine with the tps disconnected? while i was doing the swap i broke it so i got the tps from my sohc and replaced it.....now it runs with or witout....if i plug it in after a while of driving it will idle really lowabout 2 turn off....with the tps off it was idle around 600 rpm....im currently running a stock p28....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hialeahzbg »</TD></TR><TR><TD CLASS="quote">i have a 93 cx and i have an lsvtec in there.....now my question is y does the car run fine with the tps disconnected? while i was doing the swap i broke it so i got the tps from my sohc and replaced it.....now it runs with or witout....if i plug it in after a while of driving it will idle really lowabout 2 turn off....with the tps off it was idle around 600 rpm....im currently running a stock p28....</TD></TR></TABLE>
It will run fine, the ecu just doesn't use the signal from the MAP and your idle will change. I ran my car at the track with no TPS hooked up with no problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hialeahzbg »</TD></TR><TR><TD CLASS="quote">so its normal for the car 2 run fine without the tps???</TD></TR></TABLE>
Yes.
Yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hialeahzbg »</TD></TR><TR><TD CLASS="quote">i dont know what the factory specs are i just put it in and thats it</TD></TR></TABLE>
There's you're problem right there. adjust it to factory specs and your problem will be solved. Get a helm manual aka factory tech manual, it will show you how to adjust it.
