main relay clicks, rpm drops down and sometime dies
Old Nov 3, 2005 | 09:56 AM
lilbastrd's Avatar
Default main relay clicks, rpm drops down and sometime dies
hey guys, man this crx driving me nuts, i've been trying to figure out why this happen. sometime when i drive or at idle, the main relay click twice in less then a second, and the rpm drops down between the two clicks. also when i accelerate it also clicks and the rpm revs up a little and when the main relay click again its normal. the car was running perfect for a few weeks after i installed it
its a 92 CX motor in a 91 CRX Si
obd1 converted (checked my wiring and nothing seem wrong)
I have 3 main relays and it does the same thing.
i clean out the IAC
not throwing any code at all.
what else can i check??
thanks
Old Nov 3, 2005 | 04:13 PM
lilbastrd's Avatar
Default Re: main relay clicks, rpm drops down and sometime dies (lilbastrd)
ever happen to anyone?
Old Nov 3, 2005 | 06:30 PM
RA61825's Avatar
it happened to me like a month ago, i would drive the car and then the rpm would fall and the car would die. i would wait a bit and the car would startup fine. just change the main relay i change mine and it fixed the problem right away. My old relay it would click too
Old Nov 3, 2005 | 06:37 PM
HCivExoo's Avatar
check your engine and battery grounds. If you have a bad ground that relay will make that clicking niose too. just check the battery ground and the ground on the thermostat housing, and also at the power steering pump.
just something to check before you spend the some 40 $$$ on the relay
Old Nov 3, 2005 | 09:06 PM
lilbastrd's Avatar
Default Re: main relay clicks, rpm drops down and sometime dies (HCivExoo)
thanks for the reply guys, gona check those thing out first thing in the morning
Old Nov 4, 2005 | 08:56 PM
jdeemseerx's Avatar
also try cleaning the connections to the relay...
tangerinebeast
13
Apr 13, 2019 06:03 PM
Grey_accord
Apr 11, 2014 03:31 AM
my2sons
12
May 16, 2007 12:33 PM
DeviousCTR
Jun 28, 2006 03:43 PM
92-h23a1
Jul 10, 2003 04:37 PM
