AEM intake q's on 89 CRX Si
Old Mar 8, 2002 | 06:51 PM
Quik89Si's Avatar
Default AEM intake q's on 89 CRX Si
Okay, I've been thinking about buying the AEM CAI for a while now. I've got an 89 CRX si with the stock motor w/172k on it, it still feels strong but seems to burn a bit of oil. Will this intake make a noticeable difference on my current setup? Also, if later on down the road I swap in a D-series VTEC engine or even a B16, will the intake still fit?
Oh and BTW I'm getting it for $179 out the door = Intake, shipping and taxes. Anyone got a better deal?
Thanks,
Alex
Old Mar 8, 2002 | 08:31 PM
keithv's Avatar
Default Re: AEM intake q's on 89 CRX Si (Quik89Si)
an intake on your car should make a somewhat noticebale difference. usually a h/e help, too as those 3 mods are the basic building blocks for motor mods.
i would think the intake should still fit if you went to a d series vtec motor. not sure about the b16.
$179 out the door isn't bad, but it isn't great. try check in the best buys forum for pricing info.
Old Mar 8, 2002 | 08:39 PM
HyperREV's Avatar
New User
Default Re: AEM intake q's on 89 CRX Si (breaka_1_9)
my AEM made a noticable gain on my D16 w/ header and exhaust.. it also swapped over to my b16, although the 2.5" piping is a tad small for my setup now, otherwise its a great buy
Old Mar 8, 2002 | 09:03 PM
Smoothy's Avatar
Default Re: AEM intake q's on 89 CRX Si (HyperREV)
I used to have one of those. Noticed a slight gain around 4800rpm. I don't think its worth your time or money. Mine was $180 shipped also. I would just get a generic one if I just had to have one.
Old Mar 9, 2002 | 12:27 PM
Malgerus's Avatar
If you put a JDM B16A in your 89, You'll have to block off or add provisions for a ton of vacuum hoses. I suspect it's the same with other VTEC's too.
On my 89', I didn't have the money fora CAI. So, I removed all the stock piping until I had just the airbox. Then, I cut the hole going into the airbox into a large rectangle. It's ghetto fabuluos, but it helped
BIGthings
Apr 8, 2005 04:11 PM
puffsef
Feb 23, 2005 12:48 PM
bigblueandyellow
Oct 30, 2004 03:44 AM
sirexer2779
Dec 10, 2003 03:35 PM
chirp2hrd
Apr 15, 2003 05:24 AM
