Help with pretty loud "KNOCKING"
Old Nov 3, 2005 | 09:29 AM
sniperslayer's Avatar
Default Help with pretty loud "KNOCKING"
k, i have a 92 Civic HB, and for a while it's been making this heavy "KNOCKING" sound under the car, i can feel it like it's hitting the undercarrige of the car in between the gas pedal and the cat
i've checked pretty much everything, and it's nothing to do with the Contol arms, CV joints, boots etc. all that looks good, i thought it might have been loose exhaust, but it doesnt seem like thats it either?
it only makes this sound when it's in gear, if i coast in neutral it wont make it anymore until i put it back in gear and power is being given
any ideas?
Old Nov 3, 2005 | 09:30 AM
.Ry's Avatar
.Ry
Default Re: Help with pretty loud "KNOCKING" (sniperslayer)
Since your in gear and there is a load on the engine check your motor mounts.
Old Nov 3, 2005 | 11:30 AM
Soccerking3000's Avatar
Default Re: Help with pretty loud "KNOCKING" (turner7205)
were you in an accident? is the exhaust hitting the shifter?
Old Nov 3, 2005 | 11:56 AM
LShatchie's Avatar
Default Re: Help with pretty loud "KNOCKING" (Soccerking3000)
sounds like a axel
Old Nov 3, 2005 | 02:39 PM
Default Re: Help with pretty loud "KNOCKING" (LShatchie)
pretty sure it's not an axle...
i guess the exhaust could be hitting the shifter, but i cant move the exhaust at all by hand, so unless driving it puts a tonne of vibrations and force on the piping, it doesnt seem to move all that much
Old Nov 3, 2005 | 02:44 PM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sniperslayer &raquo;</TD></TR><TR><TD CLASS="quote">pretty sure it's not an axle...
i guess the exhaust could be hitting the shifter, but i cant move the exhaust at all by hand, so unless driving it puts a tonne of vibrations and force on the piping, it doesnt seem to move all that much</TD></TR></TABLE>
Just because you can't move it with your hand doesn't mean it's not loose. Have you even seen an engine flex when it's turned on? The engine is going to flex a lot, it may be too loose for the engine, but it may seem tight when your hand.
Old Nov 3, 2005 | 06:15 PM
Default Re: Help with pretty loud "KNOCKING" (JDM-EJ1)
so by the exhaust being lose, do u think it would be just the hangers or what
Old Nov 3, 2005 | 06:18 PM
Redline96LX's Avatar
* B A N N E D *
My friends car did this, and it was in the exhaust pipe before the cat. his spark plug wire was bad, and not sending any spark, so all that extra fuel was burning in the pipe, making a loud "knocking" just like you said. Check the resistence of the wires, check the plug to make sure its firing.
Old Nov 3, 2005 | 06:38 PM
1993civicex's Avatar
Default Re: Help with pretty loud "KNOCKING" (Redline96LX)
ever hear the term piston knock? thats what it sounds like to me
Old Nov 3, 2005 | 06:57 PM
Default Re: Help with pretty loud "KNOCKING" (1993civicex)
it's not coming from the motor at all....
i can FEEL the vibration under my feet, like it is knocknig directly under my feet, it's not just a sound
Vague
Apr 26, 2015 01:05 PM
slikz714
Dec 3, 2005 02:42 AM
knutz
Jul 17, 2005 08:55 PM
H22A4 Prelude
Jan 19, 2005 03:43 PM
