ABS Help on 94 ls
my abs lights turns on after a few minutes of driving, not when i start my car, when i tried to get codes off my 94 ls nothing happened could this be because the light hasnt turned on? how can i get the codes if the abs light is not on. It is telling me nothin is wrong, but 2 minutes after my car is on bam ABS light is back on. i check out this after searching https://honda-tech.com/zerothread?id=978933 but no help. please help
My 1994 Acura Integra LS SE
http://www.cardomain.com/ride/2148783
Check all the wheel sensors. I believe there is a procedure outlined in the service manual to check the output of the sensors using a digital multimeter.
It could just be one of the sensors, the ABS computer, or the ABS modulator. The modulators cost about $700 rebuilt, by the way. The sensors would be the least expensive item to fix.
I suppose I should have asked this, but when the light comes on, does ABS function? Try to induce an ABS stop while the light is on.
Under the glove compartment is a blue plug that is not plugged into anything. With the switch in the off positioin, bend a paperclip in a U shape and jumper the plug. Turn the ignition switch to the ON position without starting the car. It will blink one time and then there will be a pause. After the pause, it will blink in one second increments. There will be a 5 second pause, and then it will start blinking again. Count the number of blinks in each sequence. That should give you a 2 digit code. There are several threads in this forum that will give you the meaning of each code. Good Luck!
