HELP! abs light came on and i hear a wierd noise from the right side....read please!!
Old Mar 8, 2002 | 06:31 PM
gokooljapan's Avatar
Default HELP! abs light came on and i hear a wierd noise from the right side....read please!!
first of all i have a 93 integra GSR......here is the problem:
hi there, i recently just replaced my passenger side axle and after driving for about 50 miles i start hearing this wierd noise...kinda like a loose belt noise BUT NOT a belt..(ya know because there is no belt on the right side of the motor)....anyways it just sounds like a strange noise.....and my abs light came on once......
this sounds comes on and off...even at stops, when the car isnt moving.so it cant be the axle....what could it be????? please help!
thanks
Old Mar 8, 2002 | 10:10 PM
Veil_Side_'s Avatar
Default Re: HELP! abs light came on and i hear a wierd noise from the right side....read please!! (gokooljap
Okay try this. As dumb as it sounds check for any loose parts including lugnuts, take a look at the wheelbearing and hub.
Does it make that noise when you have your foot on the brake or it just makes the noise while the car is on?
Old Mar 9, 2002 | 01:23 PM
ILOVEGIRLS's Avatar
check your tranny fluid to make sure its not too low. just a thought
Old Mar 9, 2002 | 04:40 PM
i dont hear it no more????? ...thanks guys for the input.....its cool now i guess?
Old Mar 9, 2002 | 10:43 PM
92sleepR's Avatar
New User
Your guess about the ABS system is probably correct. Check to see if there is any brake fluid leaking and have the ABS brake system bled by a shop. Given that your ABS light came on this is the likely source of the noise.
You can also check the ABS light code by jumping the service check plug. If the code indicates low system fluid pressure there is your culprit.
Mike
vxnine
Jul 12, 2006 11:28 AM
Mike1486
Jan 17, 2005 01:20 PM
wrxvt
Nov 23, 2004 10:12 AM
xD
Feb 14, 2004 05:59 PM
Mr. Softee
Sep 10, 2001 05:56 PM
