flywheel differences
Old Nov 2, 2005 | 09:12 PM
Trench_Rat's Avatar
Default flywheel differences
i need to get a new clutch for my jdm ef7 race car , i beleive that the flywhel is an 88-89 asince the clutch contact area is 205mm to suit the 200mm clutch plate of an 88-89 correct? what i need to know is will a clutch intended for an 88-89 d16 or d15 crx fit my flywheel?
Old Nov 2, 2005 | 11:08 PM
Tyson's Avatar
Default Re: flywheel differences (Trench_Rat)
yeah, thats correct. but you also have to match up the number of splines on your tranny input chaft. the 88 had a different number than the rest of the later years.
Old Nov 3, 2005 | 11:31 AM
Trench_Rat's Avatar
its a 20 splin input shaft not a 21 so im guessing one of thoe 89 90 91 crx all model kits would do the trick?
Old Nov 3, 2005 | 12:41 PM
31flavorscivic's Avatar
Default Re: (Trench_Rat)
I fucked this one up and bought a 90-00 clutch kit for my 89 flywheel. Luckilly I had a 94 flywheel sitting around which I used. My advice: Get a flywheel from 90-00 (lightened? ) and buy the kit for it.
I couldn't find a kit for an 89 anyways, it might be filed under 89 integra or something, but yea I just converted to 90+.
http://bumrockerforlife.mine.n...h.pdf
Old Nov 3, 2005 | 02:08 PM
Civiclized's Avatar
good post, some useful info hear
Old Nov 3, 2005 | 02:43 PM
Mach69's Avatar
Default Re: flywheel differences (Civiclized)
For some reason, Honda decided to be weird from 88-90.
88 flywheels: 21 input splines with a clutch size of 200mm
89 flywheels: 20 input splines with a clutch size of 200mm
90 flywheels: 20 input splines with a clutch size of 212mm
91 flywheels: 20 input splines with a clutch size of 212mm
Old Nov 3, 2005 | 03:51 PM
Trench_Rat's Avatar
hey thanks for the info guys looks like i need an 89 si kit. I wonder how those 89 90 91 kits work then with the different clutch size it doesnt make much sense
Old Nov 3, 2005 | 03:55 PM
Tyson's Avatar
you can make a hybrid clutch kit. or you can get a different flywheel.
Old Nov 3, 2005 | 04:37 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trench_Rat &raquo;</TD></TR><TR><TD CLASS="quote">hey thanks for the info guys looks like i need an 89 si kit. I wonder how those 89 90 91 kits work then with the different clutch size it doesnt make much sense</TD></TR></TABLE>
who sells those? Sounds like someone gave out misinformation because an 89 clutch will not worth with a 90 flywheel.
Kinda like how the lug nuts at Checker's said they would work with my civic, which was a bunch of bullshit.
Old Nov 3, 2005 | 04:51 PM
Trench_Rat's Avatar
i dont want to et a new flywheel becasue i have a toda chromoly which wasnt cheap. Thoe kits are sold by xtd i think so yeah they need a kick in the butt
Old Nov 3, 2005 | 06:27 PM
joshman's Avatar
I have an 88 CRX Si so I feel your pain. I ended up building my own clutch kit. I got a kevlar clutch disc from SPEC for an 88 Accord 2.0, 91 CRX Si Action PP, and a flywheel from Evolution Industries for a 90-00 Civic. The throwout bearing and pilot bearing are the same for your year.
rex89sir2
Aug 28, 2009 02:36 PM
janz3n
Apr 14, 2007 06:06 PM
Servo
Oct 14, 2005 06:37 AM
pisetup
15
May 30, 2004 02:08 AM
