how big of tires can you go in a civic?
Old Nov 2, 2005 | 09:07 PM
riseagainst's Avatar
Default how big of tires can you go in a civic?
how big of tires can you go can u go on a 99 civic wihtout rubbing on the wheel well??
Old Nov 2, 2005 | 09:08 PM
JDMlyfestyle's Avatar
Ive seen 225 on a civic with no problems
Old Nov 2, 2005 | 09:47 PM
alright thanks cuz i was thinking of getting 215s and was wondering if it would rub or what not
Old Nov 2, 2005 | 09:49 PM
Luserkid's Avatar
Default Re: (riseagainst)
With the right offset and rolled fenders you should be fine.
Old Nov 2, 2005 | 09:54 PM
duggy's Avatar
i recommend rolling your fenders if you're going to go that wide.
Old Nov 2, 2005 | 09:57 PM
civicyellow's Avatar
it depends on the size of wheel and offset, it also depends on what type of tire it is as well, some tires have a more square tread pattern (yoko a520), where as some tires have rounded tread pattern (pirelli p7000). so some 205 look more like 215, and vice versa
Old Nov 4, 2005 | 08:08 AM
alright thanks
Old Nov 4, 2005 | 02:32 PM
allanonjj's Avatar
My bud runs 215/45 16 Azenis' on his ek but he has to have it a little high up in my opinion
Old Nov 4, 2005 | 06:14 PM
Stripped Honda's Avatar
99-0104
Default Re: (allanonjj)
just because you have a wider tire doesent mean your going to get better traction ... use the proper size tire for the wheel and you will be fine ...
Old Nov 4, 2005 | 06:49 PM
CiSmoEk4's Avatar
yeah i had 215/45/16 falken azenis on my ek and it rubbed. i did have to raise my car a little bit to run those tires. Now that i have the 195 advan neovas i can lower it more. Are you planning on putting the 215's on a 15 or 16 inch rim??
Records
Mar 16, 2012 09:04 AM
decko
Nov 9, 2010 06:17 AM
xlasianizelx
Nov 2, 2009 01:05 PM
DjBurns
Oct 3, 2008 04:30 PM
bluebullet
Jan 5, 2006 11:29 AM
