Texas -OK -LA (Sales) Texas, Oklahoma, Louisiana
FS: Very clean turbo del sol
Old Nov 2, 2005 | 09:06 PM
red_crx's Avatar
Default FS: Very clean turbo del sol
When driven to work and meets its been driven on 7-10psi .... When i got the car it was on 18psi but i turned the boost down to 7psi. Its seen 16psi and thats the most i've pushed it too... This car has been garaged kept and well taken care of...
This car has Cold A/C !!!!
Engine
2000 Integra LS motor with 77,xxx current miles
1999 Integra Ls tranny with 62,xxx current miles
Competition stage 4 clutch 3,000 current miles
6 puck sprung
Competition 10-pound flywheel
Turbonetics T3/T4 50 trim 0.63 A/R
Rev Hard front mount intercooler
In Line Pro stainless steel exhaust manifold lifetime warranty
Tial waste gate with custom dump tube
HKS super sequential blow off valve
Custom Intercooler piping
Rev Hard Intake with K&N filter
2.5-3.0 inch down pipe
Steel braided oil feed and drain lines
Skunk 2-intake manifold
Hondata S200 with boost tuned by Jason Herrera 300 hp 280 tq
Precision 680cc injectors
Walbro 255 lpm fuel pump (in tank)
B&M fuel pressure regulator
Msd Blaster SS coil
Msd external coil dist. Cap
Msd 3 bar map sensor
ENDYN positive crank case breather system
Fuidyne aluminum radiator
FAL slim line fan
Turbo XS boost controller
Poly motor mounts
Full custom 3 inch mandrel bent exhaust
Suspension
Koni five way adjustable shocks
Eibach sport line springs
Skunk 2 front camber kits
Ingalls rear camber kits
Vtec del sol front and rear sway bars
Some poly inserts just the ones that make a difference
Front and rear stainless tower braces
Manuel steering conversion with reservoi
Brakes
Brembo Drilled and slotted front rotors
VGX pads
Stainless braided brake lines on all four corners
Vtec del sol rear disc conversion
DOT 4-brake fluid
Interior
HKS turbo timer
Auto meter ultra light Boost/vacuum gauge
Auto meter ultra light oil pressure gauge
Auto meter ultra light water Temp gauge
Auto meter ultra light air/fuel ratio gauge
Dual pillar pod
Custom gauge pod in stock middle vents
Kenwood CD player
6.5 kicker front speakers
6.5 Memphis rear speakers
8 inch Cliff audio 500 watt speakers
Custom sub box for del sol behind seats (no comfort compromised)
Sony 800 watt amp
Battery located in trunk
Leather wrapped steering wheel
Asking $9,500 obo...to contact me call at 972-809-3664 or email me at phatmr2@hotmail.com
Old Nov 2, 2005 | 10:36 PM
JDM00SI's Avatar
willing to part out?
Old Nov 3, 2005 | 08:42 AM
red_crx's Avatar
Default Re: (JDM00SI)
sorry, not willing to part out
Old Nov 4, 2005 | 02:01 PM
red_crx's Avatar
Default Re: FS: Very clean turbo del sol (red_crx)
bump
Old Nov 6, 2005 | 07:43 AM
curioso's Avatar
hey man is htere anything wrong with the car, any codes, grinds, let me know man thanks
oh has the car ever been crash?
Old Nov 6, 2005 | 11:36 AM
red_crx's Avatar
Default Re: FS: Very clean turbo del sol (curioso)
as far as I know the car is flawless....no codes, no grinds. the car has not been crashed..as far as i know
Old Nov 6, 2005 | 11:40 AM
jdm y0's Avatar
a bit expensive but clean bump
JDMH22HATCH
Dec 16, 2007 11:46 PM
kabooki
Jun 20, 2007 05:07 PM
atsdelsol
Sep 10, 2005 02:47 PM
atsdelsol
Sep 10, 2005 01:33 PM
