Removing ABS on a DA. Quick Question?
I am finally getting around to taken the abs off my 1992 GSR. I have a local guy that has a JDM XSI front clip. The question i have is will the XSI lines and proportioning valve work on my integra. Im thinking it will, but i just want to double check.
Here is a good link on how to do it:
http://www.g2ic.com/forums/sho...g+abs
To anwser questions before they are ask.. I'm taking it off to have more room in the engine bay and get rid of the part that sits on the crossmember. . Im doing another turbo build.
i did this before on my friends car, you have to change master w/ booster, perportioning valve, the two hard lines to the front two wheels and you have to custom lengthen and bend two hard lines from the perportioning valve to the rear brake lines on the fire wall, then you can remove the whole abs unit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicyellow »</TD></TR><TR><TD CLASS="quote">i did this before on my friends car, you have to change master w/ booster, perportioning valve, the two hard lines to the front two wheels and you have to custom lengthen and bend two hard lines from the perportioning valve to the rear brake lines on the fire wall, then you can remove the whole abs unit</TD></TR></TABLE>
I can keep my master cylinder. I just have to get a fitting. Im just wondering if the XSI stuff will work??
i dont think xsi hard lines will work... if you dont want to bend your own i have a set of USDM RS non abs lines and the correct prop valve. PM me or email me at M_rob@mail.com if you want to buy them i have no use for them anymore. will sell for $50 i paid $80 for everything 8 months ago. peace
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mrob91GS »</TD></TR><TR><TD CLASS="quote">i dont think xsi hard lines will work... if you dont want to bend your own i have a set of USDM RS non abs lines and the correct prop valve. PM me or email me at M_rob@mail.com if you want to buy them i have no use for them anymore. will sell for $50 i paid $80 for everything 8 months ago. peace</TD></TR></TABLE>
I pm'd you...
I pm'd you...
as you can see all lines are included along with prop valve, clips and grommets. lines are in very good shape, and you can see fittings are not rounded off and the threads are in good shape.
Thanks man.. Ill send the money order out monday
That propertioning valve looks differnet then the one in this pic.. That looks like the part that sits behind the ABS unit that the rear lines go into.
http://www.imagestation.com/al...idx=4
Modified by G"UNIT at 12:10 PM 11/5/2005
JimmyAtlantis
Dec 8, 2005 10:38 AM
