!!!!!SICK PROB NO VTEC HELP!!!
Old Nov 2, 2005 | 06:28 PM
myhatch98's Avatar
Default !!!!!SICK PROB NO VTEC HELP!!!
I have read many of these forums and have not gotten an answer to my messed up problem. here it is VTEC will not activate. I have tried 2 vtec solenoids and i have checked the continuity of all the vtec wires. also checked for pins in head and they are all in correct area. i have enough oil no dents in the oil pan and still no vtec please help.
my setup
h23 block with all h22 internals including oil squirters, removed balancer shafts completely, and built head with cams.
Old Nov 2, 2005 | 06:43 PM
sicky's Avatar
grammer nawzi
Default Re: !!!!!SICK PROB NO VTEC HELP!!! (myhatch98)
motor, ecu, clean install? A little more info might help out.
Old Nov 2, 2005 | 06:44 PM
myhatch98's Avatar
Default Re: !!!!!SICK PROB NO VTEC HELP!!! (sicky)
i have a p28 chipped ecu with an obd1 jumper harness i have tried obd2 computer as well as stock obd1 gsr. what other info do you need
sicky's Avatar
grammer nawzi
One more thing, have you checked to see if the solenoid is getting the correct amount of amps?
Old Nov 2, 2005 | 06:48 PM
myhatch98's Avatar
i checked the pressure switch which is at 11.77 and the vtec pressure switch wire worked fine with old setup of gsr motor. not sure if this answers your question but all wires worked fine with old setup had a shop look at it and they have no clue with what is going on. help me
Old Nov 2, 2005 | 06:53 PM
crackerjacker006's Avatar
Are u sure its not hitting vtec cause its sometimes hard to hear with a stock setup. Also u shouldnt feel it when it comes on, it will make a smooth transition.
Old Nov 2, 2005 | 07:25 PM
myhatch98's Avatar
Default Re: !!!!!SICK PROB NO VTEC HELP!!! (carjacker006)
i have skunk2 stage2 cams i should hear vtec
Old Nov 2, 2005 | 08:35 PM
1993civicex's Avatar
theres ur problem u changed the cams............are u sure there vtec cams? cause it should matter
Old Nov 2, 2005 | 09:59 PM
Quiks66's Avatar
Default Re: !!!!!SICK PROB NO VTEC HELP!!! (1993civicex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1993civicex &raquo;</TD></TR><TR><TD CLASS="quote">theres ur problem u changed the cams............are u sure there vtec cams? cause it should matter </TD></TR></TABLE>
I'm sure he knows they are Vtec cams, noob.
MyHatch98 - Are you getting any CEL's?
Old Nov 2, 2005 | 10:30 PM
myhatch98's Avatar
Default Re: !!!!!SICK PROB NO VTEC HELP!!! (Quiks66)
i think i solved my problem thanks guys for your help i didnt know that the block had a jet that had to be removed when putting an h22 head on. once again thanks guys. and yes they are VTEC cams.
Old Nov 3, 2005 | 03:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quiks66 &raquo;</TD></TR><TR><TD CLASS="quote">I'm sure he knows they are Vtec cams, noob.
MyHatch98 - Are you getting any CEL's?</TD></TR></TABLE>
hey sometimes the company tells u there v-tec cams and there not hapend to my friend they turned out to be tuned cams w/out v-tec and cranks out more than the v-tec timing does
Ben Petrocelli
22
Jun 6, 2019 09:12 PM
TheSickestDC2
Dec 7, 2009 02:29 PM
H22Prelude420
Dec 3, 2008 09:20 PM
tcontesh
Apr 5, 2006 06:11 PM
myhatch98
Nov 5, 2005 01:03 PM
