i am getting a b16a1 will any b16 parts fit on it?
Old Nov 2, 2005 | 06:21 PM
89civich22's Avatar
Default i am getting a b16a1 will any b16 parts fit on it?
Old Nov 2, 2005 | 06:24 PM
kulangot's Avatar
Default Re: i am getting a b16a1 will any b16 parts fit on it? (89civich22)
why not...
Old Nov 2, 2005 | 06:25 PM
lodo1's Avatar
Default Re: i am getting a b16a1 will any b16 parts fit on it? (kulangot)
your asking if b16 parts will fit a b16a1? umm, simple answer, yes they will fit
Old Nov 2, 2005 | 06:28 PM
trrbl1bmx's Avatar
Do not listen to anyone, only d series parts will fit that b16a1 since its first gen. And only small chevy parts will fit ford v6
Old Nov 2, 2005 | 06:56 PM
89civich22's Avatar
Default Re: i am getting a b16a1 will any b16 parts fit on it? (tdocrx)
so if it says a honda for 92-95 and it is a b16 it will fit on the 89-91 b16?
Old Nov 2, 2005 | 08:14 PM
91 Civic B16's Avatar
a lot of parts on those engines are interchangeable, i.e. head gasket, cams, water pump, timing belt. there is not a great deal of difference between b16a1, a2 besides sensors, wiring, and a few improvements over the years of making these motors. Ive heard some internal parts are different, for example, the oil spray bars for the newer gen b16a are extruded aluminum, and the 1st gen are cast aluminum. you can do a search and see that a lot parts are pretty much the same for the different generations of motor. correct me if im wrong guys.
Old Nov 2, 2005 | 10:27 PM
civicyellow's Avatar
most things are exactly the same, the a1 and a2 just came out at different years
Old Nov 2, 2005 | 11:38 PM
Rywire's Avatar
Default Re: (civicyellow)
a1 is euro b16a
buzlink
Oct 23, 2007 03:57 PM
DA92GS
Jan 30, 2005 06:09 AM
burningoil
Sep 10, 2004 06:57 PM
