Main bearing clearences.
Old Nov 2, 2005 | 05:59 PM
B-B-K's Avatar
Default Main bearing clearences.
I just started throwing together my LSV. Everything is going to be brand new. Crank was micro polished all that good stuff. Im running ACL std bearings and ran into a lil clearence problem.
Cap clearences
#1 2 thou
#2 1 thou
#3 15 thou
#4 1 thou
#5 2 thou
In the helms the std is .0009-.0017 for caps 1-2-4-5 and 2 thou is the service limit. So Im on the border for #s 1 and 5.
#3 cap has a .0012-.0017 So im sittin in the middle there witch is good.
Im asking this on the All motor forum cuz I want to know what you guys like to run. Im happy with the other numbers from 2-3-4. I want to run a lil tight cuz I heard thats way to go for NA. But those 2 thous scare me. I can go to Honda tomorrow and pick up some brown bearings if they have them in stock. Brown is thicker to bring the clearences closer I believe.
Right now as it sits I have everything torqued down to specs and the cranks spins like butter. I have never felt a crank spin so freely and nice before.
Thanks for your time and knowledge.
Matt
Old Nov 2, 2005 | 06:29 PM
DonF's Avatar
Default Re: Main bearing clearences. (B-B-K)
How are you checking this?
Old Nov 2, 2005 | 07:17 PM
B-B-K's Avatar
Default Re: Main bearing clearences. (DonF)
Err forgot to say, Im checking with green plasta gauge.
I bought the motor from a kid...from what it sounded like, he ran this motor pretty hard. I figured it would be fine since I bored out the block and had everything cleaned.
Old Nov 3, 2005 | 11:53 AM
d16dcoe45's Avatar
I like everything towards 0.0020"--the 0.001" is tight for a high-rpm motor. All of my mains are from 0.0016" to 0.0020"--oil pressure at idle (when motor is warmed up) is around 50 lbs. Motor runs fantastic.
Old Nov 3, 2005 | 01:54 PM
DonF's Avatar
Default Re: Main bearing clearences. (d16dcoe45)
Agreed.
Old Nov 3, 2005 | 03:32 PM
B-B-K's Avatar
Ok, well.....it looks like Im going to leave 1-3-5 alone and get thinner bearings to run a larger clearence for 2 and 4 witch are at 1 thou.
Now, my next problem....I went to order some new bearings from HondaAutomotive parts online and I got confued as hell. I know I need to get a bearing one size thinner. The lettering on my block was CBBBB.
What it came out to be is
#1 B3 = Green
#2 B3 = Green
#3 B2 = Yellow
#4 B3 = Green
#5 C3 = Brown
Im not unerstanding why my readings are so loose and then so tight if the ACLs are supposed to Green. Yes everything is nice and clean. Brake cleaned everything and blew it off with the air hose.
Back to the ordering of the bearings....I went to http://www.hondaautomotivepart...ISTON
I dont know what bearing to order. They list by letters but that doesnt do me any good. They list the same bearing twice also with two different part numbers.
18452 020 BRG B, MAIN (LOWER)
18453 020 BRG B, MAIN (LOWER)
What do they mean by Bearing B? Should they have numbers with it also. Cuz with the bearing chart, bearing B can mean Pink, Yellow, Green, Brown.
I prolly got you guys confused as hell on what Im trying to explain, its just I have so much info running through my head right now. Hope this is somewhat understandable.
Thanks guys
Matt
Old Nov 3, 2005 | 04:02 PM
DonF's Avatar
Now you need to check the numbers-letters on the crank. Between the 2 it gives you the brg. color.
Old Nov 3, 2005 | 08:04 PM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B-B-K &raquo;</TD></TR><TR><TD CLASS="quote"> They list the same bearing twice also with two different part numbers.</TD></TR></TABLE>
There are two different bearing manufacturers-so Honda differentiates between them by the suffix 003 or 004, depending. Same bearing. It can get confusing.
Old Nov 3, 2005 | 10:16 PM
B-B-K's Avatar
The numbers and letters on my crank are....
#1 B3
#2 B3
#3 B2
#4 B3
#5 B3
I know I need to go a color thinner for journals 2 and 4 witch would be Yellow, but on that online Honda site, there are no listings for color. So how would I go about ordering the thinner bearing for my situation? Thats what Im tryin to figure out.
Thanks for all the help.
Old Nov 3, 2005 | 10:24 PM
b19coupe's Avatar
Red-Pink-Yellow-Green-Brown-Black-Blue. Thinnest to thickest. If you want to go one step looser than yellow, you need pink. Dealership parts guy can look it up for you.
Old Nov 4, 2005 | 12:35 PM
B-B-K's Avatar
Default Re: Main bearing clearences. (b19coupe)
I know I need to go a color thinner on 2 and 4, its running greens now but its to tight, so I need Yellows.
Haha, my parts guys dont know anything over at my Honda dealership. I had to show him the rear main seal, I basicly looked it up for him on the computer.
Just trying to figure out what bearing on the Honda online store I need to order that resembles a yellow bearing. Any one know?
Old Nov 4, 2005 | 03:25 PM
CHEETAH's Avatar
try to keep 1, 5 bit tight and 3 loose ... 2,4 moderately tight.
with plastigage you better be check with 70-80 degree room temperature.
Old Nov 6, 2005 | 08:53 AM
d16dcoe45's Avatar
Default Re: Main bearing clearences. (CHEETAH)
I know hondaautomotiveparts.com is confusing with the bearing codes--since they don't list them by colors. Here is how it breaks down (thanks to Earl!!)
A=Blue thickest
B=Black
C=Brown
D=Green
E=Yellow
F=Pink
G=Red thinnest
Hope this helps, Jay.
Old Nov 6, 2005 | 07:09 PM
B-B-K's Avatar
Awsome man, that does help out a lot!
Thanks
Old Dec 13, 2005 | 07:25 PM
S9i1R's Avatar
Here this should help if you haven't already found it https://honda-tech.com/zerothread?id=715490
Peter Brady onlyonweekndz
Nov 13, 2007 02:43 PM
xxmastermindxx
Jun 14, 2007 03:05 PM
Riceboy891
Aug 4, 2005 05:11 AM
mattb16a1civic
May 16, 2005 02:24 PM
B pwr
Jul 10, 2003 06:19 AM
