suspension problems :(
Old Nov 2, 2005 | 05:19 PM
Bjorn20's Avatar
Default suspension problems :(
ever since i had my dads friend install my new struts and springs on my ef9, whenever i go to start up the car in neutral, the rear end makes a loud horrible sound, but when i put it in gear it goes away, it only happens when i just go outside to start it up after its been sitting there for a couple hours... but i dont get why it does that, probly cuz the suspension was put on wrong or something. but would an alignment help it at all?? im thinkin it wouldnt since it just adjusts your tires, toe in, toe out, camber angles and stuff, dont think it has to do with suspension.
Old Nov 2, 2005 | 05:40 PM
RCautoworks's Avatar
Default Re: suspension problems :( (Bjorn20)
Sure the muffler or piping is not hitting anything ?
Old Nov 2, 2005 | 05:42 PM
SD_Lurker's Avatar
HT White Ops
that has nothing to do with your suspension. I dont understand what starting your car has to do with your suspension. Even if you start your car and it makes a noise I can garuntee you that its not your suspension. I would check your exhaust.
Old Nov 2, 2005 | 05:57 PM
Bjorn20's Avatar
hmmm ok, its just that it started happening like a week after i got new suspension, so i thought it might be that, but ill check out my exhaust then, thx
Old Nov 2, 2005 | 06:06 PM
Default Re: (Bjorn20)
The one exhaust hangers is right around there, he might of knocked something loose.
Old Nov 2, 2005 | 07:45 PM
turbodcivic510's Avatar
Default Re: (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">The one exhaust hangers is right around there, he might of knocked something loose.</TD></TR></TABLE>
Old Nov 3, 2005 | 02:07 PM
Bjorn20's Avatar
lol well u guys are smart, it did have to do with the exhaust, i guess when i got it lowered the rear bumper hit the exhaust tip and the exhaust pipe is vibrating against the bumper when i start it up, so thats whats causing the noise. i pushed it down a little and the noise stopped, let it go and it went again, so im gonna have to pry it down or put something in between the pipe and bumper or something
99tegjawn
Suspension & Brakes
Apr 30, 2011 08:31 AM
656delta
Nov 2, 2009 08:24 PM
stocktonhidlude
Nov 5, 2006 06:42 PM
Kellindal
Jun 17, 2002 02:58 PM
