tach help??
ok guys i took the monster tach out and i wanted to hook up stock one.well i ran the wire i used for my big tach i ran over to the stock one cause the stock wire has a short in it.now it aint working.does anyone have any ideal why its not working.the wire im useing goes straight to the blue wire on the dizzy so it should work????? someone
please help me out.
please help me out.
hey..... you didn't post what car you have and considering you're in the crx / EF fourm im guessing you got a 88 to 91.
"well i ran the wire i used for my big tach i ran over to the stock one cause the stock wire has a short in it.now it aint working.does anyone have any ideal why its not working."
If you're sure that wire is good, works fine on the monster tach and is connected directly to the blue on the dizzy..... maybe you're tapping into the wrong one on the cluster? OR maybe the tach on the cluster is no good?
i'll quote myself from this other threaad :::
(thread)
https://honda-tech.com/zerothread?id=1359344
(quote)
"hey... ok that prob took more than 15 or 20 mins.... this should answer your question....
http://www.geocities.com/knigh...r.htm
hey.... even on the guage cluster its blue... according to the diagrams, its b10 or b11 (the b side should have the most pinouts)....
good luck "
if you're not to sure about which wire is what on the cluster.... visit that site i posted on geocities.com.... it's accurate info and you should be able to wire in a cluster (as long as you can understand diagrams)...
good luck and keep us posted on what happens...
(thread)
(quote)
good luck "
i knew how it was wired but thanks for the wireing dirgram i collect them so.but i think its the tach in the stock cluster is fried so im just going to hook up the monster tach till i find new cluster.
90crxdriver
10
Nov 4, 2006 12:14 PM
DRAG14ciVHBKSI
Aug 14, 2002 06:30 AM
