Cable VSS/ Electronic VSS... will this one work?
Old Nov 2, 2005 | 03:44 PM
crexer's Avatar
Default Cable VSS/ Electronic VSS... will this one work?
Ok im wiring up a JDM gauge cluster and need an electronic speed sensor. I went to the local yard today and got one for a B series. The one of the left is the cable driven and the one of the right is the electronic one. Will the electronic vss just drop right in or do I need to do something else? It seems as if the gear on my new vss is bigger than the old cable driven one.
Any help appreciated...
Old Nov 2, 2005 | 04:07 PM
goforbroke's Avatar
MEAT PATTY
Default Re: Cable VSS/ Electronic VSS... will this one work? (crexer)
The gear appears to be longer, but they seem to be the same width from the picture. I just put in a 99 si guage cluster in my hatch a couple weeks ago and I used a d-series vvs and everything worked.
Old Nov 2, 2005 | 04:40 PM
Chase's Avatar
Default Re: Cable VSS/ Electronic VSS... will this one work? (goforbroke)
yea i used a 96 D series one Works fine
Old Nov 2, 2005 | 05:44 PM
ham's Avatar
ham
i dont know why the gear is taller but im pretty sure it will work.
Old Nov 2, 2005 | 06:40 PM
crexer's Avatar
Default Re: Cable VSS/ Electronic VSS... will this one work? (ham)
so no mixing and matching the 2 speed sensors? The new electronic vss bolted in fine...
Old Nov 3, 2005 | 04:00 PM
crexer's Avatar
guess i'll let ya'll know how it works. Does anybody know why there isnot a brake light on the jdm ef gauge cluster?
Old Nov 3, 2005 | 04:06 PM
Pee Wee's Avatar
B and D series VSS's are interchangable.
Old Nov 3, 2005 | 04:52 PM
onePOINTsix's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crexer &raquo;</TD></TR><TR><TD CLASS="quote">guess i'll let ya'll know how it works. Does anybody know why there isnot a brake light on the jdm ef gauge cluster?</TD></TR></TABLE>yes there is... it's looks like a circle with 2 lines on the outside of it... thats the best way i can describe it
Old Nov 4, 2005 | 03:47 PM
Sgt_Ox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crexer &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
by the looks of it, I had the same one, and it worked fine in both my J1 and YS1 tranny.
RACEPAK
Nov 9, 2023 07:24 AM
dannyb18c
May 11, 2012 02:04 PM
Turbo Dan
10
May 15, 2008 11:25 PM
TMC_EF
Jul 16, 2007 10:37 PM
dr_latino999
Jan 30, 2007 04:37 PM
