Custom 4 lug to 5 lug conversion
Old Nov 2, 2005 | 03:25 PM
acura_el2000's Avatar
Default Custom 4 lug to 5 lug conversion
I have access to a CNC lathe, and a CNC mill, and i am thinking about making a 4 lug to 5 lug conversion for my Acura EL, so i can roll on some Acura RSX type-s gunmetals. (if someone is selling some and are within 4hrs of london, Ontario, let me know..including the U.S.) i will make it using aluminum, or steal, and it will be 1/3" or 1/2" thick. i will CNC 4 bolt pattern, and 5 bolt pattern, then weld and cut flush the 4 lugs, and weld on some new 5 lugs. any thoughts or suggestions are very welcome.
Old Nov 2, 2005 | 08:58 PM
skr33t_rac3r's Avatar
sounds like alot of work maybe u could just have the rsx rims redrilled to 4 lug
Old Nov 2, 2005 | 09:16 PM
redzcstandardhatch's Avatar
something different
Default Re: Custom 4 lug to 5 lug conversion (acura_el2000)
or buy the parts and do it the proper way...
sounds risky unless your highly experienced.
Old Nov 3, 2005 | 07:54 AM
The guy who will be doing the welding is certified, and hes been a welding instructor for a few years, so im confident in his abilitys. The total cost of this will probly be around 30$ for the metal, if that.
Old Nov 14, 2005 | 01:42 PM
I still gotta find some gunmetal rsx rims! we've alread machined the steel for the brackets, they fit on the 4 bolt pattern nicely and there only 1/2 inch thick. we made reccesses for the 5 lug bolts to be welded in flush, and lock in. ill post pics as soon as I can.
Old Nov 14, 2005 | 02:05 PM
nonsense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acura_el2000 &raquo;</TD></TR><TR><TD CLASS="quote">I still gotta find some gunmetal rsx rims! we've alread machined the steel for the brackets, they fit on the 4 bolt pattern nicely and there only 1/2 inch thick. we made reccesses for the 5 lug bolts to be welded in flush, and lock in. ill post pics as soon as I can.</TD></TR></TABLE>
so your wheels will stick out 1/2" further than stock?
Old Nov 14, 2005 | 04:10 PM
Kookz's Avatar
Resident Vagabond
You don't weld wheel studs on unless you want to die. They should press in from the rear.
Old Nov 14, 2005 | 05:26 PM
xerox445's Avatar
Default Re: Custom 4 lug to 5 lug conversion (Kookz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kookz &raquo;</TD></TR><TR><TD CLASS="quote">You don't weld wheel studs on unless you want to die. They should press in from the rear.</TD></TR></TABLE>
Old Nov 14, 2005 | 08:19 PM
Default Re: Custom 4 lug to 5 lug conversion (xerox445)
Oh there going to be pressed in at the back, but im also going to weld them, for peice of mind aha. and ive measured, and 1/2 inch would make my wheel almost flush, with a little, less, to the body, were going to do a mock-up and then we might machine id down to 1/3 inch if necessary.
Old Nov 14, 2005 | 09:05 PM
Extent's Avatar
Even so you've still managed to ruin your scrub radius, unless you're using a different wheel offset that compensates for that extra half inch plate.
Old Nov 14, 2005 | 10:30 PM
Niles's Avatar
Kudos for coming up with a new and creative solution to a problem. Let me just ask though did you check with salvage yards anywhere near you about getting 5 bolt hubs? I would assume you could find a 5 bolt hub with the right OD and press it into your 4 bolt bearing on the existing upright for less trouble, less work, slightly more cost, and OEM reliability. Personally that's what I would do for safety reasons, hope it works out for you. Loosing a wheel even at 30 miles an hour could kill...
P.S. prelude guys have done the 4 to 5 bolt conversion as above...
Old Nov 15, 2005 | 07:01 AM
nonsense's Avatar
Default Re: Custom 4 lug to 5 lug conversion (Niles)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Niles &raquo;</TD></TR><TR><TD CLASS="quote">Kudos for coming up with a new and creative solution to a problem. </TD></TR></TABLE>
wheel adapters are a new invention?? LOL
Old Nov 15, 2005 | 02:22 PM
Niles's Avatar
Default Re: Custom 4 lug to 5 lug conversion (nonsense)
I thought it was a better way to start a post than "I think this is unsafe, and that's why nobody does it this way outside of 10 dollar e-bay products" Maybe I was wrong, LOL!
j0KeRzWilD
Mar 19, 2009 08:44 AM
Jibin
Honda Civic (2001 - 2005)
Jul 25, 2008 08:14 AM
naeghatch
Suspension & Brakes
Oct 23, 2007 06:31 PM
GregblkEx04
Acura TL, RL & ZDX
Dec 23, 2004 09:33 AM
