94-01 JDM ITR springs and shocks onto a 96 civic?
I have the 5 lug conversion on my 1996 Civic hatchback and I was wondering if 94-01 JDM ITR shocks and springs would bolt right on or are they a different size then 96-00 civic shocks and springs? Thanks!
the only problem you will have is that the ITR rear shocks require you to get the CTR rear LCAs. (different mounting style)
EKs use the same length rear LCA as the CTR. (longer)
EGs use the same length rear LCA as the ITR. (shorter)
other than that they should work.
Sleepy0132
Jan 22, 2009 10:12 PM
