Throttle bracket on y8 mani swap...
Old Nov 2, 2005 | 10:54 AM
Wilky's Avatar
Default Throttle bracket on y8 mani swap...
Do I need this throttle cable bracket when swapping this mani onto a y7?
Also, since this is an auto mani with a three-wire IACV, do I still have to swap the throttle bodies?
Old Nov 2, 2005 | 12:39 PM
Wilky's Avatar
Default Re: Throttle bracket on y8 mani swap... (Wilky)
Any help?
Old Nov 2, 2005 | 12:43 PM
haveaniceday's Avatar
well im sure some ppl didnt use it .. but i advise using it .. or getting it, whichever .. automatic Y8s and all Y7s(auto and manual) have 3 wire iacv
Old Nov 2, 2005 | 01:28 PM
sicones's Avatar
Default Re: Throttle bracket on y8 mani swap... (haveaniceday)
you have to use the throttle body that came with the y8 because the throttle rotor is facing the wrong direction, also I would like to see you drive your car without the throttle cable bracket (yes you need it)
Old Nov 2, 2005 | 01:48 PM
xswimordiex's Avatar
anyone have a part number for that bracket? i'm collecting pieces for a swap myself and no luck with that piece yet
Old Nov 2, 2005 | 05:39 PM
Wilky's Avatar
So you are saying I need the y8 bracket?
Old Nov 2, 2005 | 08:03 PM
https://www.hondaautomotivepar...82%29
number 6 in the picture
Old Nov 2, 2005 | 09:28 PM
VTcivicHB's Avatar
The y8 bracket doesn't work because the y7 has a different throttle cable, its hard to explain. I had to custom make my own bracket, that was the only downside to doing the conversion for me. Good luck.
Old Nov 2, 2005 | 09:33 PM
compwc18's Avatar
Default Re: (VTcivicHB)
Ive done this once, and to my knowledge you have to use the y8 throttle bracket, but if you use the y8 throttle bracket you might need the y8 throttle cable, I can't remember if my buddy had that or not, I believe he did.... But if you don't have it you can use a z6 bracket and your stock throttle cable.... Don't quote me on that, that's what I've heard of other people doing....
Old Nov 2, 2005 | 09:56 PM
Wilky's Avatar
Default Re: (compwc18)
Bump for anyone who has use the z6 bracket... Is this the solution?
Old Nov 2, 2005 | 11:10 PM
Redline96LX's Avatar
* B A N N E D *
Default Re: (Wilky)
You may not use the y7 bracket as its completely different. Your stock y7 throttle cable will work, tho it will be a little long, its fine.
Old Nov 3, 2005 | 02:00 AM
max23's Avatar
Default Re: (xswimordiex)
D16Y8 throttle cable bracket Part # 16411-P2J-000
you could re-use your Y7 TB but you have to swap the TB Spring and Rotor from a Y8 or i guess any TB that ain't a down-draft one just like the Y7.
Old Nov 3, 2005 | 08:05 AM
Wilky's Avatar
Default Re: (max23)
Thanks for all the great input
Old Nov 3, 2005 | 11:50 AM
lowgman's Avatar
I second that, you do need the Y8 throttle bracket for sure. I found out the hard way (missed a day of work cause Honda didn't have it in stock).
Old Nov 3, 2005 | 12:10 PM
turboman's Avatar
When I did a y8 gsr throttle body swap I kinda made my own. Kinda jerry rigged and I have been meaning to find out what others did to solve this. I may go back and make another bracket but the one I have now is kinda ghetto.
Project Dad
Mar 28, 2011 04:12 PM
Crossbreeder
Feb 1, 2010 10:11 AM
hondasport2000
May 23, 2004 02:56 PM
fastcrxsi90
Mar 20, 2003 01:10 PM
