Need some help with new Camīs
Old Nov 2, 2005 | 10:20 AM
CivicEG6-R's Avatar
Default Need some help with new Camīs
Hi!
Im gonna change my ITR cams, but i really donīt know what camīs i should replace them with?
Is there anyone here who can give som good advice?
Is Skunk2 Pro 1 series good fo my engine?
And what springs, retainers and camgear should i use with the cams?
And maybe some bigger Injectors.
My setup today is
B18C4 block with B16B pistons (A compression around 12.7)
Ported B16 head with ITR Cams, ITR Retainers, ITR Springs and ITR valves
Skunk2 Intake manifold
66mm TB
240cc injectors
Adj fuel pressure regulator
DC 4-1 Header
2―" Apexi N1 catback exhaust
Comptech Icebox
ECU tuned with Crome
Only using 99 octan fuel.
Best Regards Niklas
Old Nov 2, 2005 | 04:06 PM
zman's Avatar
Default Re: Need some help with new Camīs (CivicEG6-R)
With that high of a compression i would run at least stage 2 cams. I would personally run buddy club 3+'s and buddy club valvetrain. Or maybe some Toda C's.
Which ever cam you choose use its recommended valvetrain.
Old Nov 2, 2005 | 05:11 PM
1FastCoupe's Avatar
JUN 3 all day long...
Old Nov 3, 2005 | 08:44 AM
CivicEG6-R's Avatar
Ok Thanks!
What a about Rocket Motorsport? M23? Maybe Skunk2 PRO 2, or even some higher stage from the BLOX serie?
408EJ1
29
Apr 2, 2011 08:51 AM
sol_1
Nov 11, 2007 10:56 AM
Andrew Sutherland
Dec 10, 2006 12:33 PM
jaystation
May 10, 2005 04:20 PM
juggernaut
Oct 5, 2003 06:05 AM
