wheel hop issues
to start off things with, i have a 96 gsr and when i launch at 3k adn drop the clutch, i get mad wheels hop. this even occurs when i lauch at 2.5 k. this never happend until after about a week when i got my prothane inserts in. i have driver tranny and firwall in. all the mounts are fine and not broken. give advice plese or what can cause this.
prothane inerts on driver , tranny , and firewall.
i have 205/45 16 bfg gforce sports.
again. this didnt happen until a week after i got the inserts in.
Do you have stock suspension? If you it can't handle the added strain caused by the insets. The inserts transfer more power to the ground that otherwise would be lost flexing the mounts, if you mounts are no longer flexing that power goes to the ground, unloading your front suspension causeing the wheel hop. Drop the car or stiffen you the suspension so fix it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GsrGilbert »</TD></TR><TR><TD CLASS="quote">is there anyreason that your just dumping the clutch? have we tried just slipping it out. there is really no reason to ever dump the clutch.</TD></TR></TABLE>
Yep try feathering it, should reduce wheel hop, and eleminate it on the track. Did for me and that was with stock suspension at the time.
The easies way to get rid of wheel hop is to lower the car and stiffen in to as much as you can stand. Stiffer it is less wheel how u'll have. Wheel hop is caused by the suspension not able to control unloading when you launch. Either feather the clutch or go to a more agressive spring/shock.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackLudeSi »</TD></TR><TR><TD CLASS="quote">The easies way to get rid of wheel hop is to lower the car and stiffen in to as much as you can stand. Stiffer it is less wheel how u'll have. Wheel hop is caused by the suspension not able to control unloading when you launch. Either feather the clutch or go to a more agressive spring/shock.</TD></TR></TABLE>
Wow people sure talk a lot without knowing WTF is up.
I have stiff springs and new shocks and I have bad wheelhop Even in the rain.
TRACTION BARS= Wheelhop Eliminator.
let me add this happend about 2 weeks after i got my inserts and clutch in. everything was find until then. launcing and dropping the clutch before the inserts were in didnt cause it to wheel hop
had the same problem with my car. funny thing is that when i changed my suspension to the tein ra it seemed like it got worse. my suggestion to you is to put a traction bar. i recently put a full-race one on mine and though i havent tested it at the tracked yet when i lauched it at 6k and dumped the clutch the tires just spun a little bit and the car went with no wheel hop whatsoever.
TRACTION BARS ,They will virtually eliminate wheel hop, improve traction and greatly improve your 60 foot times.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackLudeSi »</TD></TR><TR><TD CLASS="quote">Wow people sure talk a lot without knowing WTF is up.
TRACTION BARS= Wheelhop Eliminator. </TD></TR></TABLE>
are you really experiencing wheel hop or is it just you and your clutch...
often times when you just drop the clutch, its trying to grab the gear, and when releasing the clutch too fast it skips some teeth giving the feeling that your encountering wheel hop but in all reality its just you.
dropping the clutch too fast while its trying to grab the gear while its spinning i think will give you the effect that your getting wheel hop.
correct me if im wrong.
trust me its wheel hop. my friend at the track said he seen the fron bounce up and down like a damm bouncing ball. ill try feathering the clutch and see what happen. when i dump the clutch, it hops like crazy but then i let go of the gas and get back on it it stops. and when shifting into second, wheel hop occurs once again. so could this be my clutch grabing to hard>? i got ACT extreme with street disc
Clutch.... Gears....? no dude no clutch gears dont mean to be an ***. but yea traction bars are sweet and for us Da drivers we can get rid of that satanic front crossmember for lets say a fat *** downpipe. o and the traction bar will stop wheel hop..... why are u dropping the clutch anyways?
