Just my luck...MAJOR CLUTCH LINE ISSUE!!!! READ/RESPOND PLEASE!!!!!!
Old Nov 2, 2005 | 06:58 AM
jackhunt321's Avatar
Default Just my luck...MAJOR CLUTCH LINE ISSUE!!!! READ/RESPOND PLEASE!!!!!!
I had to cut my steel clutch line in half for a retarded reason(would rather not say). LOL Replacing the line is out of the options. Can I use a peice of rubber fuel line to put the two ends back together? I don't beleive this line can be flanged because it has a seam on it......PLEASE HELP!!!!!!!!!!!!!!!!!!!!!! Thanks -Jack
P.S. Tried to flange it, but my brand new flanging tool would not work. The steel is to hard.
Old Nov 2, 2005 | 09:01 AM
Hawkze_2.3's Avatar
Default Re: Just my luck...MAJOR CLUTCH LINE ISSUE!!!! READ/RESPOND PLEASE!!!!!! (jackhunt321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jackhunt321 &raquo;</TD></TR><TR><TD CLASS="quote"> Can I use a peice of rubber fuel line to put the two ends back together? </TD></TR></TABLE>
No. It will never hold the pressure...trust me. Maybe you could get some brake line from the auto parts store and bend a new one for now.
Old Nov 2, 2005 | 11:43 AM
gsrious's Avatar
there are aftermarket ones(stainless steel braided lines) made especially for that cluth line.
Old Nov 2, 2005 | 11:40 PM
stealthmode62's Avatar
Default Re: (gsrious)
I made a couple stainless hydro clutch lines a while back, and never really marketed them. If you need one let me know. It's a 5 ft (or so) -3 stainless line.
Old Nov 3, 2005 | 02:33 PM
Chiovnidca's Avatar
A compression fitting may work if you didn't hack out too big af a piece.
Huberts5-lugBB1
Apr 20, 2016 03:23 PM
AFAccord
Jul 8, 2008 07:28 PM
si937
Feb 15, 2006 12:40 PM
jtracing919
Dec 22, 2004 07:32 AM
youngkow
Jan 17, 2003 01:00 PM
