Suspension & Brakes Theory, alignment, spring rates....
neeed help indentifying GC
Old Nov 2, 2005 | 06:38 AM
vietnameeh's Avatar
Default neeed help indentifying GC
i found a real good price on some Ground controls...
the seller says they are custom spring rates ...the exact ones i want 450f and 550r
is there a way i can verify that this truly is a custom spring rated ground controls and not some off the shelf rated ground controls
Old Nov 2, 2005 | 07:50 AM
gabebauman's Avatar
Default Re: neeed help indentifying GC (vietnameeh)
Have him take a picture of the springs showing the numbers printed on them.
Old Nov 2, 2005 | 07:54 AM
vietnameeh's Avatar
right on thx...
Old Nov 2, 2005 | 08:02 AM
gabebauman's Avatar
Default Re: (vietnameeh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietnameeh &raquo;</TD></TR><TR><TD CLASS="quote">right on thx...</TD></TR></TABLE>
Old Nov 2, 2005 | 10:22 AM
Tyson's Avatar
Default Re: (gabebauman)
How do I tell what my spring rates are?
Ground Control sells Eibach Race Springs (ERS) which are labelled by 3 different values in the following convention: length . diameter . spring rate. However, ERS will come labelled in either Metric (mm.mm.N/m) or English (inchx100.inchx100.lbs/inch) units. 180.64.61 is the same thing as 700.250.350. The conversion from Metric to English is (/.254, /.254, x5.7) "/" means "divide by", "x" means "multiply by".
http://www.norcalcrx.org/tyson/coilover.html
Old Nov 3, 2005 | 09:04 PM
chrisw85's Avatar
Tyson, that is an excellent link, btw. Good info in there.
It is interesting to see that H&R OE sports and Sport springs both have the same spring rate (276F/220R), just different amounts of lowering, .75" versus 1.75" respectively.
redDAinteg
Suspension & Brakes
485
Feb 6, 2026 06:31 PM
Cole D
Suspension & Brakes
10
Jul 10, 2007 07:05 AM
hazard_one
Suspension & Brakes
Feb 17, 2005 07:15 PM
MikeTV
Mar 5, 2004 09:52 AM
Tweakmeister
May 31, 2003 02:33 PM
