Every winter my steering wheel squeaks
Old Nov 2, 2005 | 06:08 AM
Anthony's Avatar
Mr. Fuch-yu
Default Every winter my steering wheel squeaks
Man, everytime it starts to get cold here, my steering wheel squeaks. Left turn or right turn, it is worse than nails on a chalkboard. Does anyone know what a dude can do to fix this? I appreciate any help.
-Red
Old Nov 2, 2005 | 08:19 AM
Anthony's Avatar
Mr. Fuch-yu
Default Re: Every winter my steering wheel squeaks (nitrared)
Anyone?
Old Nov 2, 2005 | 08:49 AM
JDM-97CX's Avatar
Are you positive it is the steering wheel or could it be coming from outside the car?
Old Nov 2, 2005 | 08:56 AM
Anthony's Avatar
Mr. Fuch-yu
Default Re: Every winter my steering wheel squeaks (JDM-97CX)
-Red
Old Nov 2, 2005 | 09:08 AM
TurboFart's Avatar
does it smell like burning rubber/plastic?
Old Nov 2, 2005 | 10:22 AM
Anthony's Avatar
Mr. Fuch-yu
Default Re: Every winter my steering wheel squeaks (TurboFart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboFart &raquo;</TD></TR><TR><TD CLASS="quote">does it smell like burning rubber/plastic?</TD></TR></TABLE>
No. It is just this really annoying squeaking sound that makes me contemplate driving off the road instead of turning. Btw, the car is a 94 civic ex coupe. I don't know if that would make a difference, just thought I would add that just in case.
-Red
Old Nov 2, 2005 | 10:27 AM
JwM's Avatar
JwM
Try this.
At the bottom of the steering column is a plastic cover. It covers the yoke of the steering column where it connects to the P/S rack.
Remove the cover and set it aside.
Get a flathead screwdriver and some ball bearing grease, or even white lithium or something similar.
You should see the rubber ring around the bottom of the yoke all the way to the bottom. That rubber is dry (and cold) grease it up! See if that helps.
Old Nov 2, 2005 | 10:41 AM
EvilPinkEye's Avatar
Default Re: Every winter my steering wheel squeaks (JwM)
got the same damn prob..happens alot, seems to be right at the the wheel and column cover..ill try this in the week end
Old Nov 2, 2005 | 11:19 AM
Anthony's Avatar
Mr. Fuch-yu
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JwM &raquo;</TD></TR><TR><TD CLASS="quote">Try this.
You should see the rubber ring around the bottom of the yoke all the way to the bottom. That rubber is dry (and cold) grease it up! See if that helps.</TD></TR></TABLE>
Will do. I'll let you know if this doesn't work. Thanks.
-Red
Old Nov 2, 2005 | 11:36 AM
Anthony's Avatar
Mr. Fuch-yu
Also, I think that there should be a sub-forum on our home page that is labeled as maintenence for things such as this. I dunno... I just didn't think it would be a bad idea.
-Red
Old Nov 3, 2005 | 06:47 AM
Anthony's Avatar
Mr. Fuch-yu
Ok. I got the plastic cover off but I am having a hard time finding the rubber ring. Here are a few pics so that you can maybe photoshop an arrow or circle in to show me where the ring is:
Thanks for any help.
-Red
Old Nov 3, 2005 | 07:55 AM
dpkelly's Avatar
Gents,
I discovered this years ago. There's a thin metallic piece of metal (like a bobbypin) that's used to allow electrical contact between the horn on a moving steering wheel and the stationary steering column. This will squeek in the winter. If you bend the "bobbypin" away from the contact plate, you will have no horn. I just put up with it. If you oil it too much, your horn may be less loud.
Old Nov 3, 2005 | 10:48 AM
Anthony's Avatar
Mr. Fuch-yu
Default Re: Every winter my steering wheel squeaks (dpkelly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpkelly &raquo;</TD></TR><TR><TD CLASS="quote">There's a thin metallic piece of metal (like a bobbypin) that's used to allow electrical contact between the horn on a moving steering wheel and the stationary steering column.</TD></TR></TABLE>
Where exactly is this piece of metal. I couldn't care less about a f'ing horn. Plus, around here all the horn is good for is provoking a middle finger.
-Red
Old Nov 3, 2005 | 04:40 PM
dpkelly's Avatar
It might be easier to see if your steering wheel is off. It's been years since I last looked at mine. I think the pin contacts the cable reel assembly. Your pics are zoomed in too close.
I thought a quiet steering wheel was nice but having a horn is better than that. You'll see when you get into a situation where u really need it. Someone will ask you why you didn't beep your horn before hitting that little kid that darted out in front of you.
Old Nov 4, 2005 | 04:36 AM
Anthony's Avatar
Mr. Fuch-yu
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpkelly &raquo;</TD></TR><TR><TD CLASS="quote">Someone will ask you why you didn't beep your horn before hitting that little kid that darted out in front of you. </TD></TR></TABLE>
F'ing little brats shouldn't be in the road. J/K. No man I'm not a speed demon on the streets. Plus, kids don't play outside anymore... they have NIN-10-DOH.
-Red
Old Nov 4, 2005 | 05:13 AM
dpkelly's Avatar
Well, there will be other times where you will wish you had a horn. You may be hit by a drunk driver who couldn't hear your horn.
Believe me you will need one.
thirsk66
Oct 23, 2015 06:20 PM
speedball3
Oct 21, 2008 11:18 AM
EG6TEEZO
Dec 29, 2005 10:29 PM
b18cEK
Mar 23, 2004 06:48 AM
stripes777
Jul 5, 2003 11:38 AM
