swa[ help dohc zc motor into a ef hatch
Old Nov 1, 2005 | 11:26 PM
turbozcteg's Avatar
Default swa[ help dohc zc motor into a ef hatch
does any one know hoe to or where i can get info on doing a zc in my hatch
my motor is ready to drop in but im not trying to screw anythign up
and also will my si tranny work on the zc motor
any help is greatly appreciated
thanks
~jake
Old Nov 1, 2005 | 11:28 PM
Stunna MIKE's Avatar
Default Re: swa[ help dohc zc motor into a ef hatch (ogre)
yes it will.. and its a great tranny for the swap.. but i am also very interested.. i want to do a ZC swap in my 90 SI hatch as well..
BUMB
Old Nov 1, 2005 | 11:30 PM
gutterslide's Avatar
Default Re: swa[ help dohc zc motor into a ef hatch (AaronJDM)
http://www.gutterslide.com/fou....html
Old Nov 1, 2005 | 11:38 PM
turbozcteg's Avatar
Default Re: swa[ help dohc zc motor into a ef hatch (gutterslide)
ok so how do i switch over the side mount from my motor to the zc ??????
Old Nov 3, 2005 | 08:19 PM
turbozcteg's Avatar
ok so its not a zc its a d16a1 which is the usdm zc motor
the side mount is different than the zc and i was told i need to change it over and i need to know what mount to use ????
Old Nov 4, 2005 | 04:31 AM
mahatma's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ogre &raquo;</TD></TR><TR><TD CLASS="quote">ok so its not a zc its a d16a1 which is the usdm zc motor
the side mount is different than the zc and i was told i need to change it over and i need to know what mount to use ????</TD></TR></TABLE>
That's no good. You'll have to make your own. The motor you have only swaps easily into 85ish Civic Si's. Sell it and start over
Old Nov 4, 2005 | 03:21 PM
31flavorscivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mahatma &raquo;</TD></TR><TR><TD CLASS="quote">That's no good. You'll have to make your own. The motor you have only swaps easily into 85ish Civic Si's. Sell it and start over </TD></TR></TABLE>
Old Nov 4, 2005 | 06:23 PM
Sikocivic's Avatar
You have the WRONG motor. Mounts are wrong,tranny won't bolt up and the axels won't work. You need the motor stamped ZC or D16a8 or 9
Old Nov 5, 2005 | 04:50 PM
zccr-xsi's Avatar
Default Re: swa[ help dohc zc motor into a ef hatch (Sikocivic)
it dont matter what it says cause the jdm zc and euro zc are the same.the only diff is that the a8 came with a rover fined valve cover.
Old Nov 5, 2005 | 06:13 PM
TommyBB's Avatar
http://www.fourthgenhatch.com/
I belive thats it
LSVTECKING
Sep 9, 2003 05:42 PM
joey1320
Aug 22, 2003 08:30 PM
DarkZachiel
10
Sep 2, 2002 10:09 AM
