shim kit
Has anyone tried the shim kits for camber instead of buying an entire rear camber kit? Is the price difference worth it, or would I be better off purchasing a rear camber kit?
just do the washer trick. Head down to ACE and pick up a few washers that will fit the bolt that bolts into the chasis. The lower the drop the more washers you use for each side. I believe I either used 3 or 4 for each side. It cost me no more than $3.
drewbie
13
Jan 6, 2005 03:13 PM
