what happing if u run an automatic p28 ecu on manual h22?
well i wouldnt wanna find out..but you will be in limp mode.. and i know the SOHC maps are not even good for the H22 so i would not skimp out cause it will cause more harm than good to ur motor
If you could make it down the street ill give you a dollar.
Every thread you make is about a cheap *** way to work an ecu around your swap. Get a P13 and end it. Why waste more money?
so you want to run a 2.2L DOHC motor on an ECU meant for a 1.6L SOHC motor? Answer this, then proceed, do you think the h22 uses the same amount of gas as the 1.6L, or do you think it might use just a little ******* bit more. I woulndn't do it...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tr0n9h »</TD></TR><TR><TD CLASS="quote">but for the question i ask just for my knowledge, is it possible to run auto on manual without any problem?</TD></TR></TABLE>
No, you'll get a CEL.
Stop making a ton of posts. Ask all your questions in one post AFTER YOU ******* SEARCH!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tr0n9h »</TD></TR><TR><TD CLASS="quote">yea jdmshit chip is mugen, i have it. i compare both map exact same jsut different vtec crossover</TD></TR></TABLE>
THey are NOT the same program man.... Im not called the ECU guy for nothing
The mugen CHip has a revlimit of 9500 RPM's i wanna see you take a H22 to 9500
and the ignition values are completely different and the vtec cross over is not the same and not to mention that the mugen is for a 240cc injector and not for a 310cc injector so you run the possiblitly of running super rich or lean depends on the program..
but hey dont listen to me i dont know nothing.. have fun destroying your motor
Lyrikz
Sep 10, 2003 12:34 PM
