Bought a beater - Someone tell me something about it, search blows.
Old Nov 1, 2005 | 07:51 PM
-yz-'s Avatar
Default Bought a beater - Someone tell me something about it, search blows.
Just picked up a 1990 Accord EX 4-dr for $950-
Body is great, few rust spots.
Car seems to run fine, needs exhaust.
It has 148k miles and probably is in need of a tune up, what do you suggest be done to it? It's got a new clutch, tires, and brakes
I'm thinking:
plugs, distributor, wires, oil change, coolant flush... anything else?
Also need some links to fix up some interior stuff like the door handles. The cruise and power moonroof don't function either.
Help me out, I'm a VW dude and normally work on them with efficiency, Honda's I know little about. What engine code is my car?
Old Nov 1, 2005 | 08:22 PM
dmurphy2k3's Avatar
Default Re: Bought a beater - Someone tell me something about it, search blows. (-yz-)
1990 Accord EX: 2.2L(2156cc), F22A4, MPFI, SOHC 16-valve
Look in the Basic Guide to Accords for more info, in .ken's section. Its stickied at the top of the accord forum.
Old Nov 2, 2005 | 04:33 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -yz- &raquo;</TD></TR><TR><TD CLASS="quote">... what do you suggest be done to it?</TD></TR></TABLE>If you can't prove the timing belt has ever been replaced, that would be a good thing to do. Interference engine; if timing slips, it can be real bad.
How about fresh brake fluid...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -yz- &raquo;</TD></TR><TR><TD CLASS="quote">Help me out, I'm a VW dude and normally work on them with efficiency, Honda's I know little about.</TD></TR></TABLE>Once you get over the engine turning backwards, they're not so bad.
NGK plugs, NGK or Honda plug wires. I've used Bosch plugs, but lots of other people have had problems with them.
Old Nov 2, 2005 | 06:55 AM
hondamaniac1's Avatar
Default Re: Bought a beater - Someone tell me something about it, search blows. (JimBlake)
The cruise and sunroof might just be a bad dashboard switch....I have a '92 EX with bad dash lights....which turned out to be just a bad dimmer switch.
I'd suggest checking fuses and if those are good maybe, if you can, pull the switch and do a continuity test.
Old Nov 3, 2005 | 04:04 AM
-yz-'s Avatar
Default Re: Bought a beater - Someone tell me something about it, search blows. (hondamaniac1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondamaniac1 &raquo;</TD></TR><TR><TD CLASS="quote">The cruise and sunroof might just be a bad dashboard switch....I have a '92 EX with bad dash lights....which turned out to be just a bad dimmer switch.
I'd suggest checking fuses and if those are good maybe, if you can, pull the switch and do a continuity test. </TD></TR></TABLE>
Checked all the fuses and they were all good. What next? Engine wise I did a valve cover gasket, plugs, plug wires, airfilter, oil change yesterday and it's running but I noticed when I pulled the plug all the way to the left out, it was covered in oil! I think because the valve cover gasket was so bad oil was leaking down into where the plug sits? Anyhow, the plugs looked ok but I changed them out anyways. Fired the car back up and blue smoke is now coming out indidicating some oil burn. I'm assuming that it is just burning off any excess oil that was left behind???
Here's a funny one, I got in the car last night, put the ebrake down started it and everytime the clutch was engaged in or before i put her into first it would make a load whine (eeeeeeeeeeeeeeeeeee) and then stop. tranny seemed fine. then as I would shift 2nd, 3rd, 4th, etc... i would hear a click from the fuse box kinda like when a fuse blows? Any ideas? Problem went away by itself.
davidcrevenston
Feb 5, 2010 09:33 PM
RAZ'ZV6
Jun 14, 2007 03:34 AM
teh_emo_kid
Jul 19, 2006 06:56 PM
accord owner
Dec 12, 2005 01:56 AM
coolrace05
Oct 24, 2005 08:25 AM
