the P R 4 ecu into crx? what?
okay this maybe dumb and it may have a quick an easy answer but i ran outta time while looking at the ecu placement **** in my shop.
i took the old crx ecu out and was goign to place the the new pr4 teg ecu in and boom the connections are on the other side... so what now? if i turn it over i will have to weld up new screw placings so it fits right... what do you guys do?
and if anyone can help out and tell me how to get teh M F ' ing back motor mount back bolt off of the stock it would be sweet... i have tried and i stopped and figured maybe someone on here would have some tricks
what do you mean the connections are on the other side? just move the plugs around thy are not bolted down or anything just yank on em
the rear motor mount bolt you can get to from behind the crossmember if you have a wacky bent wrench or just take the front 2 bolts out and use a BFH (big ****** hammer) to turn the mount sideways, and you now can see the ****** and get to it and get it out
