Is it bad to chirp gears?
I took my dad for a ride in my car and I shifted into 2nd at 5 k and it spun then went, he's like WTF I'M NOT GONNA HELP YOU WHEN YOU BREAK IT THIS TIME!!!
I didn't see anything real bad about doing it? Iunno probably a pointless post, but I was wondering.
depends how you're "chirping" it. if you're popping your clutch then, yes it's not good on your drivetrain. by popping the clutch (esp. since you have a perf. clutch) drivetrain is engaging instantly causing what's called drivetrain shock. the function of the clutch is supposed to slip/slide so gears can mesh slowly ensuring a comfortable transition between gears. so when you dump the clutch, gears are forced to slam together thus causing the "chirp". very harsh on the teeth of gears. not to mention you also cause premature wear/damage to misc. bearings. also when chirping you're running into alot of wheel hop, which also is damaging to the drivetrain.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efhatchback »</TD></TR><TR><TD CLASS="quote">I think its fine as long as your not popping the clutch</TD></TR></TABLE>
i've never chirped the tires by letting the clutch out slowly.
This is how oil pump gears shatter. When "popping" the clutch with high HP and an aggressive clutch and sticky tires and sticky road (like drag strip) you can break stuff.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ssmdc2 »</TD></TR><TR><TD CLASS="quote">This is how oil pump gears shatter. When "popping" the clutch with high HP and an aggressive clutch and sticky tires and sticky road (like drag strip) you can break stuff. </TD></TR></TABLE>
what would that have to do with the oil pump??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by . M i c h a e l »</TD></TR><TR><TD CLASS="quote">
i've never chirped the tires by letting the clutch out slowly. </TD></TR></TABLE>
hahahaa i'd pay to see that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ernald711 »</TD></TR><TR><TD CLASS="quote">
hahahaa i'd pay to see that</TD></TR></TABLE>
what do you mean?
what do you mean?
i guess its ok ...
when you unintentionally do it 2nd or 3rd.
it will deff happen if your trying to shift at high rpms.
but i like barking the shiat out of 4th tho!
LOL
LOL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by del sol1658 »</TD></TR><TR><TD CLASS="quote">I see nothing wrong with it. Some cars just have to much power that its hard not to chirp into second or thrid.</TD></TR></TABLE>
a civic ex can chirp gears...trust me...its not the sheer amounts of power your sub 2 liter engine is putting down
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xteg95 »</TD></TR><TR><TD CLASS="quote">You chirped gears with your dad in your car? wtf is wrong with you?</TD></TR></TABLE>
lol god i hope your dad didnt buy you the car, so you can treat it like **** right in front of his face?
thats just rude
thats just rude
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ComptonsF1NEST »</TD></TR><TR><TD CLASS="quote">dont be a RICER APC NO EXHAUST *** AND TRIP GEAR EVERYTIME U DRIVE!
if u do i hate u
but occasionally when racing or a solo run is ok</TD></TR></TABLE>
a guy i see all the time with a sr20 240 ALWAYS chirps 2nd gear, every time he accelerates lol. i hope his clutch shatters and cuts his leg off
if u do i hate u
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by benb18a »</TD></TR><TR><TD CLASS="quote">
</TD></TR></TABLE>lol
do it occasionally tho
