Squeaky-Ass Neuspeed Sport Springs...
After installing my new springs, it is hard not to notice that they squeak a lot! I've been driving on them for a while thinking that the squeaking will go away once they have settled, but that has not been the case.
Is there a step i missed during installation that could have eliminated this problem before it started?
What can I do to make the squeaking go away?
Aside from the squeeking, I am verry happy with the ride, performance and looks that these springs have.
Thanks agian in advance,
NOOB
PS: The springs are on a 90 HB Si (if that makes a diff)
NOOB
YUP! you missed something. There is a step where they say you should wrap the spring in spots occationally to eliminate spring chatter. They are well aware that thier spings make noise... you should try race springs ;-) they have tons of chatter. they recommed putting some kind of rubber tubing over their springs if they are too loud.
Are there some specific brands of spring wrap that you could suggest? Oh, by the way...the strange thing is that only the front squeek really bad. I don't think the rears squeak at all. And I haven't installed any wrap or grease on the rear.
-=K
-=K
also try this:
-put the car on stands
-loosen the lca bolts on one corner
-use a jack to raise that corner till it barely lifts the car off the stand
-re-torque the lca bolts
-repeat on all corners
This may not apply to what ur hearing, but on my prelude wen i turned left it would sound like my back right spring was squeaking really bad, i would hear it over my radio which i have blaring all the time. When my slave cylinder broke my friend drove it and hurd it and wen he lifted it up it was a heat shield rubbing the crap out of my exhaust, so maybe that is your problem
