Does this axle seal look seated properly? [pic]
Old Nov 1, 2005 | 01:27 PM
turbotime's Avatar
Default Does this axle seal look seated properly? [pic]
Ok got the new axle seal in and just want to make sure its seatec orrectly before i put everything back together.. It slid in real easy until this point and now it wont go in further (by hand). Does this look right?
Thanks!
Old Nov 1, 2005 | 01:43 PM
. O M E G A's Avatar
3rd g3aR vTak
Default Re: Does this axle seal look seated properly? [pic] (turbotime)
Can't tell from that angle. But did you try tapping it with a light hammer , like a rubber mallet ? ( very lightly )
Old Nov 1, 2005 | 01:45 PM
turbotime's Avatar
no that was the next step, i just wasnt sure cause people said dont push it too far, and this is as far in as i can get it to go by hand...
Old Nov 1, 2005 | 01:46 PM
3rd g3aR vTak
Default Re: (turbotime)
Try it. Just don't hit too hard. And watch closely. For movement.
Old Nov 1, 2005 | 01:48 PM
turbotime's Avatar
ok basically the gasket has 2 lips, inner(raised) and outer, is the outer lip supposed to be flush with the tranny?
Old Nov 1, 2005 | 01:49 PM
DavidR's Avatar
I simply insert the axle to press the seal in the rest of the way.
Old Nov 1, 2005 | 01:50 PM
3rd g3aR vTak
Default Re: Does this axle seal look seated properly? [pic] (DavidR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DavidR &raquo;</TD></TR><TR><TD CLASS="quote">I simply insert the axle to press the seal in the rest of the way. </TD></TR></TABLE>This is also a good idea. But good luck !
Old Nov 1, 2005 | 02:38 PM
siregcivic's Avatar
when i did my axle seal i just used the 32 mm socket for the axle nut and tapped it gently with a hammer.. it slides in very easy it went in too far for me twice until i had it right
Old Nov 1, 2005 | 02:40 PM
si0385.'s Avatar
Default Re: Does this axle seal look seated properly? [pic] (siregcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siregcivic &raquo;</TD></TR><TR><TD CLASS="quote">when i did my axle seal i just used the 32 mm socket for the axle nut and tapped it gently with a hammer.. it slides in very easy it went in too far for me twice until i had it right</TD></TR></TABLE>
thats how ur suppose to put a seal in
Modified by turbodreamz0385 at 3:57 PM 11/1/2005
Old Nov 1, 2005 | 02:57 PM
turbotime's Avatar
ok well i just inserted the axle (with dust cover) and hopefully that pushed it in to wherever it needs to be..
Old Nov 1, 2005 | 05:45 PM
tpr's Avatar
tpr
The outer rim (rubber covered metal) should be flush with the transmission case. Use a brass drift to knock it in. work around the seal edge pushing the seal in small amounts each time till it fully seats flush with the case. Do not use the axle as it will not fully seat the seal, causing the outer lips to wear out prematurely.
Old Nov 1, 2005 | 05:49 PM
turbotime's Avatar
damnit, ill redo it tommorrow using the 32mm socket
rainman3223
Transmission & Drivetrain
Aug 15, 2010 01:13 PM
DarkBB4
Apr 22, 2007 09:29 PM
97grnrs
Oct 3, 2006 02:52 PM
97grnrs
Jun 10, 2006 09:29 PM
AgentJam
Apr 9, 2004 06:18 PM
