car on fire!!
Old Nov 1, 2005 | 11:24 AM
matthevelli's Avatar
Default car on fire!!
i was leaving work today..and i had arrived at my buddies house...i sat in my car(off) for ten minutes and when he arrived i had to move my car...i went to start it and nothing...no fuel pump purge nothing...now i just fixed this problem...main relay and ecu fues...car was working all day yesterday..all a sudden i saw smoke come from under neith the dash..i quickly jumped out and looked under..the harness that plugs into the main relay was on fire..the wire for terminal 5 or 7 in the relay was totally gone...what could of caused this..was it old wires..and i jut have bad luck..or was there to much power through the harness..(95 hatch,b16a..walbro pump)
Old Nov 1, 2005 | 11:28 AM
Project_DX's Avatar
Default Re: car on fire!! (matthevelli)
did you replace the two fuses with ones that had two high of amp's
Old Nov 1, 2005 | 11:30 AM
Project_DX's Avatar
Default Re: car on fire!! (Project_DX)
cause if they blew in the first place then something was wrong, bad ground, wires old and exposed, and you just poped some new fuses in there that were to high, you deff could have fryd that ****
Old Nov 1, 2005 | 11:31 AM
FalkenSiR's Avatar
Look for any + wires just hanging. I almost set my car on fire too by grounding a 12v source. It looked like people have been smoking in there for hours. Full of white smoke. I managed to pull the glowing red wire with my bare hands and burn myself. But at least I didn't get the car on fire
Old Nov 1, 2005 | 12:17 PM
vtecpoweredsol's Avatar
its cursed... a lot of honda's are
Old Nov 1, 2005 | 02:17 PM
Default Re: car on fire!! (fast88std)
yeah thats what i did...burned my hand instead of my car...no i replaced the ecu fuse with a 15amp likes it was....i just think it was old wires maybe shorted...i;ll fix it..i need to trace back the damaged wire and replace it..do you think i should just get a new wire harness...or should i just cut and splice?
Old Nov 1, 2005 | 03:50 PM
Lttran's Avatar
Default Re: (vtecpoweredsol)
at least ur alive and the car didnt blow up like the movies
Old Nov 1, 2005 | 04:12 PM
Iceman05's Avatar
Default Re: (Lttran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lttran &raquo;</TD></TR><TR><TD CLASS="quote"> at least ur alive and the car didnt blow up like the movies </TD></TR></TABLE>
^^ Only if you have NAWZZZ
Old Nov 1, 2005 | 04:37 PM
Default Re: (Iceman05)
bump..for brand new cabin wire harness.need one
Old Nov 1, 2005 | 05:29 PM
BlackYoshi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Iceman05 &raquo;</TD></TR><TR><TD CLASS="quote">
^^ Only if you have NAWZZZ</TD></TR></TABLE>
FOR THE LAST TIME NOS DOES NOT BLOW UP(with out gas mixture)!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Please dont believe everything in fast and the fakious (theres my 2 cent)
check your wires because i believe my friend short circuit his speakers because one of the wires didnt have resistance and we checked it out and the wire had a bare spot with lil dark spots which i believe maybe gave a spark and thank GOD and didnt catch anything on fire
Old Nov 2, 2005 | 02:19 PM
Default Re: (matthevelli)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matthevelli &raquo;</TD></TR><TR><TD CLASS="quote">bump..for brand new cabin wire harness.need one</TD></TR></TABLE>
need one
Old Nov 2, 2005 | 03:13 PM
94hatchling's Avatar
hit up the local salvage yard. i can tell you one thing.... going to honda for a wiring harness is going to cost an arm and a leg.
or if you feel up to the challenge, just rewire it with a wiring diagram, and be sure to check for the correct resistance, etc etc.
good luck.
Old Nov 7, 2005 | 10:10 AM
aight i looked over my cars..and i just decided to go and spend the money on the new wire harness....theres alot of fire damage...so im going to go this way instead of cut/splicing...i went to majestichonda.com and they have a wire harness for over 600bucks...i need to know if the cabin harness is what i def. need...i called and they said too look on the site..but those pictures arnt the best...the harness that goes into the main relay is BBQ.. and so is the plug that goes into the relay...now if i ordered the cabin relay am i going to get what i need?..
http://www.hondaautomotivepart...RNESS
Old Nov 8, 2005 | 07:49 AM
bump
Old Feb 8, 2006 | 04:53 PM
90jdmcrxdude's Avatar
so i replaced the whole cabin wire harness...and yet again..my main relay starts to smoke again...im stumped..whats the problem..could it be my fuel pump..its a walbro..
Old Feb 8, 2006 | 04:56 PM
Default Re: car on fire!! (90jdmcrxdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90jdmcrxdude &raquo;</TD></TR><TR><TD CLASS="quote">so i replaced the whole cabin wire harness...and yet again..my main relay starts to smoke again...im stumped..whats the problem..could it be my fuel pump..its a walbro..</TD></TR></TABLE> --sorry this is my post...so can anyone help me out
Old Feb 8, 2006 | 05:00 PM
Mjeden2006's Avatar
Default Re: (masteraj88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by masteraj88 &raquo;</TD></TR><TR><TD CLASS="quote">
check your wires because i believe my friend short circuit his speakers because one of the wires didnt have resistance and we checked it out and the wire had a bare spot with lil dark spots which i believe maybe gave a spark and thank GOD and didnt catch anything on fire</TD></TR></TABLE>
Genius, I'll back you up fully on that if some of these people knew anything about chemistry then the world would be a lot better place. Just so everyone knows it's pretty much impossible to blow up a car without a bomb or some well placed accelerants( i.e gasoline outside the tank)
Old Feb 8, 2006 | 05:03 PM
miamijdmcoupe524's Avatar
check and see if the main relay is actually causing the problem. switch it with another one. it always turns out to be something so stupid and simple
Old Feb 8, 2006 | 05:35 PM
Default Re: car on fire!! (miamijdmcoupe524)
i have three main relays...they all do the same things..the one wire gets to hot
Old Feb 8, 2006 | 05:38 PM
the pump does not prime and the wire starts to heat up..key on engine off..i just replaced the whole cabin wire harness it was a bitch...it didnt fix the problem..im guess its cause theres to much voltage going through that wire
hatchz6
Dec 30, 2009 05:39 AM
Jago
Aug 2, 2007 02:21 PM
86crxintheworks
Jul 13, 2006 06:48 PM
JDMdamian95
12
May 6, 2006 08:37 PM
JDMdamian95
May 3, 2006 10:44 AM
