Suspension & Brakes Theory, alignment, spring rates....
ST rear sway bar fitment
Old Nov 1, 2005 | 10:41 AM
rexwreckjr's Avatar
Default ST rear sway bar fitment
Im about to buy the ST rear sway bar for my CRX. I have a Tanabe Hyper Medallion exhaust.. Did anyone (any chassis) have trouble fitting this bar and exhaust? Anyone with this bar please post your car and exhaust and if it fit or not (pics if possible). Also where's the best deal to find one? tia
Old Nov 1, 2005 | 09:19 PM
rexwreckjr's Avatar
Default Re: ST rear sway bar fitment (rexwreckjr)
i know u have them....
Old Nov 1, 2005 | 09:44 PM
Tyson's Avatar
you will have clearance issues but can be fixed with bending and massaging the exhaust mounts.
best deal for the ST bar is summit racing.
Old Nov 1, 2005 | 10:04 PM
rexwreckjr's Avatar
Default Re: ST rear sway bar fitment (Tyson)
thank you sir.. I was looking into getting an HF sway actually. I am going to research the difference between mine and the HF and see if it is necessary.
Old Nov 1, 2005 | 10:10 PM
rexwreckjr's Avatar
grrrrr cant use pms yet... do you happen to know the size difference between the HF and DX bar? thanks
Old Nov 1, 2005 | 10:33 PM
Tyson's Avatar
same as Si. 18mm solid vs. 17.3mm hollow.
this is for the front swaybar btw, in case anyone is confused.
justinwinn
Nov 25, 2010 04:31 PM
neozero999
Mar 30, 2008 11:26 PM
synergy10
Aug 17, 2005 08:46 AM
GroundZer0 336
Jan 3, 2005 12:00 PM
2kstreetcivic
Apr 8, 2004 06:50 PM
