How do you figure out the percent of use of a fuel injector ?
Old Mar 8, 2002 | 10:46 AM
TRuST's Avatar
Default How do you figure out the percent duty cycle of a fuel injector ?
How do you figure out the percent duty cycle of a fuel injector ? Is their a guage or equation that I can use to figure that out ? Also, how do you figure out if your fuel pump can handle you injectors ? I know that you can go by the fuel per hour rating, but is there some way to test the fuel pump to make sure it is work as rated.
[Modified by TRuST, 12:22 AM 3/9/2002]
Old Mar 8, 2002 | 08:21 PM
TRuST's Avatar
Default Re: How do you figure out the percent of duty cycle of a fuel injector ? (TRuST)
TTT
Old Mar 9, 2002 | 09:45 PM
thegrinch's Avatar
Default Re: How do you figure out the percent duty cycle of a fuel injector ? (TRuST)
o.k. here is how you calculate the duty cycle ready.....
here is all the formulas you need.
max power=[injector mass rate]x[# of injectors]x duty cycle
________________________________________
BSFC
injector mass flow rate= Xcc/min
_______
10.5
BSFC--> usually between .45-.55 for all motor
Duty cycle ---> usually .85 (safe)
GOOD LUCK!!!!!!
Old Mar 22, 2002 | 11:10 AM
rioninja's Avatar
or, take the easy way out and go rc engineerings site at http://www.rceng.com
Jjb122
Dec 22, 2016 03:15 PM
svacca1
Sep 7, 2007 09:41 AM
