OIL Question
ok when i take my spark plug wires out there seems to be oil on it and same when i take my spark plugs out and i was just wondering if that was normal or not and if not what should i do thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vt4cPwn35 »</TD></TR><TR><TD CLASS="quote">the seals in your valve cover are bad</TD></TR></TABLE>
let's hope thats it, or a bad ring
It's either the valve cover gasket or the spark plug well o-rings. Luckily, FelPro sells a kit with all the gaskets for around $20. It's pretty easy to replace them but you'll have to take off the valve cover and rocker assembly to get at the spark plug o-rings. Since you're taking off the rockers, you'll need to do a valve adjustment, too.
I did this not very long ago on my 91 LX and it took a couple hours in the evening.
what the heep says it is a good advice ,, but do not remove rocker arm just yet ,, remove valve cover and replace the 4 seals on the bottom side of valve cover first, put a new v.c.gasket, clean the plug holes, put all together and see if it takes care of ur problem ,,in some cases that is all u need , however if u still have oil in spark plug tubes than u got to do as THE HEEP suggested ,,,,to remove rocker arm ...etc etc,
