strange sound need help
Old Mar 8, 2002 | 10:16 AM
JMX's Avatar
JMX
Default strange sound need help
ok last night i start hearing this *shing shing shing*metal on metal noise only when the car is moving, the onther thig is ones i have gone a few miles car and breakes(probably) has heated up it quits it does it after the car has sat for a while, sounds like front right .... probably the brake or something rubbing the rotor...how do i fix that
also i havent had to slam on the brakes any time recently so i dont know why it started, and its not the squiler on the pad
anybody elese had this problem
Old Mar 8, 2002 | 12:22 PM
owen_the_soyboy's Avatar
Default Re: strange sound need help (jmx2323)
could be a bad clutch pressure plate spring...
Old Mar 8, 2002 | 12:32 PM
95GS-R's Avatar
I get that exact same thing. I imagine it is from the brakes, but I have been to lazy to replace them. Someone else posted and said that one of the compounds Honda puts in there brake pads sends out a high pitched frequency (like a tuning fork/squeal) when there is metal on metal contact. I have a hard time explaining what the noise sounds like other than that it is a high pitched "ringing".
Old Mar 8, 2002 | 03:42 PM
LS_racer's Avatar
Default Re: strange sound need help (95GS-R)
I had a similar noise coming out of my brakes as well, turned out that my "new" caliper which Acura had installed a month before had frozen in the clamped position so it was squealing as I tried to drive it. You could feel the heat coming out of the wheel well after you'd been driving. They had to install a whole new caliper on mine. Quick test, if you can feel the heat, try putting a bit of snow in there just push it through the wheel if you get steam back out and the melted snow running out the bottom, your calipers are probably stuck in the braking position. I also unfortunately was unable to get the dealership to cover the cost of putting in the new caliper even though I still think it was because of a bad initail install.
TailZ
Honda Civic (2001 - 2005)
Oct 7, 2009 08:26 AM
96teggynonVtec
Apr 13, 2006 05:30 PM
russianroulette
Feb 8, 2004 07:51 PM
Lazydsm
Dec 9, 2003 08:35 PM
deadbirdy03
Mar 20, 2003 08:20 AM
