Speedometer not working on my 2000 Integra
My speedometer stopped working after i swaped in my new engine, i tried 2 different VSS and it still doesnt work....VTEC obviously doesnt work...can it be my ecu? i dont know because everything worked right before the swap....any input is greatly appreciated!!
CHECK YOUR SPEED SENSOR ON TRANNY BELIEVE IT OR NOT DID A CIVIC D15 SWAP. SPEEDSENSOR
PLUG WAS DIRTY AND IT DIDNT WANT TO WORK SPRAYED SOME BRAKEKLEEN ON IT PLUGGED BACK IN WORKED FINE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acuramike »</TD></TR><TR><TD CLASS="quote">CHECK YOUR SPEED SENSOR ON TRANNY BELIEVE IT OR NOT DID A CIVIC D15 SWAP. SPEEDSENSOR
PLUG WAS DIRTY AND IT DIDNT WANT TO WORK SPRAYED SOME BRAKEKLEEN ON IT PLUGGED BACK IN WORKED FINE</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acuramike »</TD></TR><TR><TD CLASS="quote">CHECK YOUR SPEED SENSOR ON TRANNY BELIEVE IT OR NOT DID A CIVIC D15 SWAP. SPEEDSENSOR PLUG WAS DIRTY AND IT DIDNT WANT TO WORK SPRAYED SOME BRAKEKLEEN ON IT PLUGGED BACK IN WORKED FINE</TD></TR></TABLE>
what is Brakekleen?
what is Brakekleen?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by realis9 »</TD></TR><TR><TD CLASS="quote">
what is Brakekleen?</TD></TR></TABLE>
its an aerosol cleaner. Its used to clean brakes off when you are working on them. Its works real good as it degreases and evaporates clean with not much residue.
Blaze45
Apr 11, 2018 12:51 PM
krazieV
Aug 7, 2008 08:43 PM
piggydog
Dec 28, 2006 05:30 PM
TodaR
Jan 21, 2004 03:16 PM
2000, 94, doesnt, fuse, integra, integras, odometer, problem, speedometer, speedometor, speedomiter, stop, stopped, work, working
