Wiring a b18a1 into a 88 hb
Old Nov 1, 2005 | 04:29 AM
DominicanEF9's Avatar
Default Wiring a b18a1 into a 88 hb
I wanted to kno if the wiring of a B18a1 (90-93 integra) OBD-0 would fit into my obd-0 hardness. Or do i need to get the hardness from a integra. because i have the hardness from the motor but not from the interior harness.
Old Nov 1, 2005 | 05:11 AM
HondaFerris's Avatar
Default Re: Wiring a b18a1 into a 88 hb (DominicanEF9)
hey if your asking about "hardness" i think your on the wrong forum....try calling a doctor...but if you have questions about swapping your LS into your 88 civic then try using the "search" feature (top right of the forum) That will give you everything you need to know about your swap I'ts been coverd a million times...
Old Nov 1, 2005 | 10:19 AM
31flavorscivic's Avatar
Your "hardness" will work with the b18a1. You actually have to use your harness. Make sure to convert to mpfi if car is dx or std
Old Nov 1, 2005 | 01:15 PM
CBURKE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DominicanEF9 &raquo;</TD></TR><TR><TD CLASS="quote">I wanted to know if the wiring of a B18a1 (90-93 integra) OBD-0 would fit into my obd-0 hardness. Or do i need to get the hardness from a integra. because i have the hardness from the motor but not from the interior harness. </TD></TR></TABLE>
Is your 88 a DPFI or a MPFI? If its a MPFI then your good and all you will need is the motor mounts, shift links and axles form a 90 to 93 integ. And make sure it is OBD0, I think some of the 93's may be OBD1. But don't hold me to that. I am gonna be doing the same swap myself. But mine is a 90 Si. good luck and you can try to search but if you don't type the right words in you will get nothing.
Old Nov 1, 2005 | 02:26 PM
mahatma's Avatar
Default Re: Wiring a b18a1 into a 88 hb (CBURKE)
Yeah the 92-93 Teg motors are OBD1. You'll need a conversion harness if it's one of those motors.
TweakedTT
Jul 26, 2008 08:07 PM
bboy_mikey
12
Nov 27, 2007 02:36 PM
Tbindas
Jan 9, 2005 08:24 PM
quicksol95
Aug 8, 2004 09:28 AM
Layziebtnh055
Apr 5, 2004 03:44 PM
