car misses sometimes
Old Nov 1, 2005 | 01:39 AM
littlegreenb18's Avatar
Default car misses sometimes
as the title says...
i have a jdm b18c controlled by a chipped p28. it runs great most of the time, but at idle it will miss a lot, and sometimes crusing at low rpm it will miss. is this a big problem? what could cause it? thanks
Old Nov 1, 2005 | 06:05 AM
Ransom's Avatar
Default Re: car misses sometimes (littlegreenb18)
a number of things could be the problem...like fuel, spark, bent valves, could also be the chipped p28.
Old Nov 1, 2005 | 08:39 AM
Default Re: car misses sometimes (LudeSH)
valves are good. plugs look good. and it did this when i was running my p72 as well. fuel filter maybe?
Old Nov 1, 2005 | 08:59 AM
Luserkid's Avatar
Full tune up.
Old Nov 1, 2005 | 09:34 AM
Default Re: car misses sometimes (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Full tune up. </TD></TR></TABLE>
like what? the oil has been changed recently, plugs look perfect, just did a valve adjustment about 2 weeks ago. only thing that has not been changed(and probably never has now that i think of it) is the fuel filter. i just don't see how that would cause it to miss. btw no cels either, shouldn't it fire a code if it misfires?
Old Nov 1, 2005 | 10:27 AM
turbotime's Avatar
ignition timing!
Old Nov 1, 2005 | 10:30 AM
Luserkid's Avatar
Seafoam
Oil change
Oil Filter
Spark plugs
Spark plug wires
Cap
Rotor
Fuel Filter
Ignitor (up to you really)
In that order.
garagespec
21
Feb 12, 2017 03:16 PM
94b16teg
Oct 29, 2006 12:00 PM
2point2
Jun 3, 2004 12:24 PM
Griffin@Camtech
Jan 30, 2004 03:05 PM
Griffin@Camtech
Jan 30, 2004 11:42 AM
