car idling weird after changing headgasket on a gsr
Old Oct 31, 2005 | 09:45 PM
itsJDMyo's Avatar
Default car idling weird after changing headgasket on a gsr
we just recently changed my buddy's headgasket on his gsr motor. when we started it up, it would idle normal, but once we open the throttle up a lil bit, then the engine would start idling from 2 to 3k rpm, and repeat itself...do you guys think maybe the timing belt jumped a tooth while we were putting it back on?
If so, how do i go about fixing this? thx. Also, about the idling problem, it was doing it before also. but it would stop after the engine gets warm. but now, it's just constantly doing it. and it has an AEBS manifold. maybe one of the lines are mixed up? we already changed the PCV valve, so that's not an issue right now.
Modified by itsJDMyo at 6:55 AM 11/1/2005
Old Oct 31, 2005 | 09:55 PM
itsJDMyo's Avatar
Default Re: car idling weird after changing headgasket on a gsr (itsJDMyo)
anybody think if it's driveable? with the conditions that it has right now?
Old Nov 1, 2005 | 08:34 AM
HONDA RR's Avatar
Check to see if all the sensors are hooked up on the intake manifold.
Old Nov 1, 2005 | 03:27 PM
smkngsr's Avatar
Default Re: car idling weird after changing headgasket on a gsr (HONDA RR)
check all the timing belt and timing, look for some vacuume leak or something...the car will not idle correctly if the timing belt is off by 1-2 tooth...
Old Nov 1, 2005 | 07:06 PM
itsJDMyo's Avatar
Default Re: car idling weird after changing headgasket on a gsr (smkngsr)
we found out it was the timing belt. it was off by 4 tooth's...lol
Modified by itsJDMyo at 8:19 AM 11/2/2005
Old Nov 1, 2005 | 11:12 PM
Ek-CoolGuy's Avatar
It's tooth's.
Old Nov 2, 2005 | 12:02 AM
brad.'s Avatar
Default Re: car idling weird after changing headgasket on a gsr (Ek-CoolGuy)
teethseses
gokblok
Aug 1, 2013 04:20 PM
igorka_91
Sep 14, 2009 01:04 PM
llevity
Jul 12, 2005 02:39 PM
crix351c
Feb 27, 2005 10:30 AM
romJones
Mar 5, 2004 07:32 PM
