civic front disc conversion
Old Oct 31, 2005 | 09:35 PM
benmyfriend's Avatar
Default civic front disc conversion
i looked in the archives and could not find anything on the subject. i know you can do the rear disc conversion for an EF with the DA rear discs but i was wondering if you could put the front discs from a DA onto an Ef? and even if you could, would it be worth it?
Old Nov 1, 2005 | 05:29 AM
HondaFerris's Avatar
Default Re: civic front disc conversion (benmyfriend)
you can and its worth it
Old Nov 1, 2005 | 06:30 AM
DelSolDon's Avatar
Default Re: civic front disc conversion (HondaFerris)
its worth it and i have a pair of complete DA integra knuckles for sale. includes hub, rotor, caliper, and near new pads. send me a PM if interested
Modified by DelSolDon at 11:00 AM 11/1/2005
Old Nov 1, 2005 | 06:33 AM
md88hfcrx's Avatar
Default Re: civic front disc conversion (DelSolDon)
i think its better and easier to do an accord wagon front disc. i think the guy called it the "jonathan mod"
Old Nov 1, 2005 | 06:58 AM
DelSolDon's Avatar
Default Re: civic front disc conversion (md88hfcrx)
no offense to jonathan, but i'm not real fond of using the wheel spacers. and its much easier to must swap out the entire knuckle than modify, test fit, modify, test fit, etc.
Old Nov 1, 2005 | 07:11 AM
CO_RaceFab's Avatar
thats the stupidest thing Ive ever heard why would you do accord knuckles if you didn't have an H in there
Old Nov 1, 2005 | 07:20 AM
md88hfcrx's Avatar
Default Re: (PFI_NAYR_ONE)
i think its a nice alternative that is ver functional and it is pretty cheap
Old Nov 1, 2005 | 07:23 AM
CRX Toad's Avatar
Yes is it worth it. I have the 4Dr 90-91 EX Knuckles with the Prelude rotor and the ITR/Accord Wagon calipers and a 260V Integra booster and MC. If it is a DD then it is probably going to be overkill. They do feel so nice though. You can use the DA kunckles as long as you are lowered.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PFI_NAYR_ONE &raquo;</TD></TR><TR><TD CLASS="quote">thats the stupidest thing Ive ever heard why would you do accord knuckles if you didn't have an H in there </TD></TR></TABLE>
WTF are you talking about?
Old Nov 1, 2005 | 08:08 AM
CRXB16T's Avatar
Default Re: (CRX Toad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">I have the 4Dr 90-91 EX Knuckles with the Prelude rotor and the ITR/Accord Wagon calipers</TD></TR></TABLE>
I have 4dr 90-91 ex knuckles and calipers that i'm gonna swap onto my car after i get new wheel bearings for them. What is the difference in Calipers between ITR and the ex calipers? Also what is the differance between EX Rotors and Prelude Rotors?
Thanks
Old Nov 1, 2005 | 08:30 AM
CRX Toad's Avatar
Default Re: (CRXB16T)
Yes the EX knuckles will be an upgrade for you. The EX rotors are only a 10.X" rotor where the Prelude's are 11". The ITR caliper is bigger than the EX caliper. If you are looking for just a nice street setup I would just do the full EX in the front...I RR my car that is why I put the bigger brakes on it. Also you don't have to, but I would suggest getting the 15/16MC from the EX (it will bolt right to your booster and you won't have to worry about moving lines around) also to give you a little bigger MC over your current MC.
Old Nov 1, 2005 | 08:49 AM
CRXB16T's Avatar
Don't worry I planned on the brake upgrade and put in the 15/16 master cylinder before i swapped the motor.
Thanks for the help.
Old Nov 1, 2005 | 10:39 AM
efpride's Avatar
i have seen on h-t that when you swap the rear discs, the wheels in the back come out of the fender like a quarter of an inch sometimes. would this happen on front also if you did the front discs?
Old Nov 1, 2005 | 10:41 AM
CRX Toad's Avatar
Default Re: civic front disc conversion (efpride)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efpride &raquo;</TD></TR><TR><TD CLASS="quote"> i have seen on h-t that when you swap the rear discs, the wheels in the back come out of the fender like a quarter of an inch sometimes. would this happen on front also if you did the front discs?</TD></TR></TABLE>
If they stick out someone probably didn't do it correctly and no the front wheels won't stick out further.
cybergreencivic
Sep 1, 2007 09:18 AM
litlekikr
Feb 8, 2005 07:35 PM
Bignasty
Jul 30, 2004 08:48 AM
