Front Passenger side wheel pushed a little back? what is BENT?? PICS!!! ASAP
Old Oct 31, 2005 | 05:05 PM
92integraVTECgsr's Avatar
Default Front Passenger side wheel pushed a little back? what is BENT?? PICS!!! ASAP
ok.. my friend hit a curb a few months ago. his front passenger side tire is pushed back a little bit. the car still drives straight and feels good..
but what is bent? is it the outer Tie Rod End???
here is a pic.. thanks
Old Oct 31, 2005 | 05:25 PM
Default Re: Front Passenger side wheel pushed a little back? what is BENT?? PICS!!! ASAP (92integraVTECgsr)
or could it also be my lower control arm?
what is the main possibility??
Old Oct 31, 2005 | 05:43 PM
ohiohonda's Avatar
Take the tire off and take a look at it? Maybe something will look bent wrong.
Old Oct 31, 2005 | 06:32 PM
JDMrps13's Avatar
Default Re: Front Passenger side wheel pushed a little back? what is BENT?? PICS!!! ASAP (ohiohonda)
somebody brought in a 98 teggy....and the owner of the car hit a curb at like 40 mph and that **** was fucke dup then passenger side wheel was really close to the fender just like yours...so i chekd it out and i replaced the lower control arm and the shock....the shock because something was hit and the top of the shock was bent ....but definatey they LCA will be bent ...trust me on that....
Old Oct 31, 2005 | 06:40 PM
Default Re: Front Passenger side wheel pushed a little back? what is BENT?? PICS!!! ASAP (JDMrps13)
thanks.. ill check that out tomorrow..
Old Oct 31, 2005 | 09:11 PM
Undercover_Skank's Avatar
my teg is the same too...but i got the car like that....ill have to check the lca again...didnt look bent to me last time
Old Oct 31, 2005 | 10:55 PM
Finger Lickin' good's Avatar
Default Re: Front Passenger side wheel pushed a little back? what is BENT?? PICS!!! ASAP (Undercover_Skank)
90% sure its your lower control arm. I hit a curb going like 20ish, my tire was all the way back to the fender. Swaybar endlink and lca was bent. More the lca than the swaybar.
Old Jan 7, 2006 | 02:48 PM
kine462's Avatar
Default Re: Front Passenger side wheel pushed a little back? what is BENT?? PICS!!! ASAP (Finger Lickin' goo
have a 90 civic hatch back and have same issues. replaced my lca and it helped but the spec is still way off (about -1.8 degree caster on passenger side). I believe that the crossmember and/or the radius rods are fubar. Looking into replacing front crossmember.
Old Jan 7, 2006 | 02:50 PM
LSRracing95's Avatar
100% positive it will be the lower control arm. how does the car steer, any vibration while driving?
Old Jun 14, 2012 | 12:30 AM
nautadogg's Avatar
My little bro recently crashed his car into a island on the driver front side. He replaced everything on that side but now the passanger wheel seems to not be rolling right . He says it like burning out. I looked at it but didnt see anything bent but i know his frame is a little bent downward on driver side. I was thinking maybe trying to put a front camber kit or tie it up to a pole and try bending the frame back a little any one got any suggestion thanks for ur time.
Old Jun 14, 2012 | 07:39 AM
Solster's Avatar
Find a body shop with a frame rack and laser liner.
just pulling it out with a pole and chain is Stupid.
there are alot of spot welds in a unibody car if you pullit wrong you can snap the welds and then the car is un safe to drive till you get the fixed correctly.
think of it like this.
take a empty pop can and crush it from top to botom
now pull the can back out and make it look as good as you can
then re-crush it. it crushes with a lot less force the second time.
so if you hit some thing and bent the Crash zone in the car and just pull it back out. next time you hit some thing it will be A LOT more damaged if it doesn't kill you.
i say this only after i saw a car that was improperly repaired after a front end crash.
the first owner hit a car at 45MPH and crushed the front end in. it was fixed by the local Mexie body shop. it looked good and even passed the inspection from Washington State patrol but 3 weeks after the New owner got the car they hit a Parked car at 30MPH and ended up with the engine in there lap and killing the passenger. turned out they never reinforced the bend to the unibody support rails under the front suspention. the car looked odd when i saw it that was a lot of damage looked as if the car started to crush right at the A pillar.
Old Jun 15, 2012 | 12:27 AM
nautadogg's Avatar
any places in orange county bend car frames back !!!!!!!!
Old Jun 15, 2012 | 07:18 AM
beecee18's Avatar
Im just gonna go ahead and say yes!
contact your local auto repair guys, or body shops and they will probably be more than happy to refer you to the guys who do work for them prior to body work.
They have to farm jobs out to these guys before they can perform the body work
Old Dec 10, 2012 | 09:24 AM
PERSIANCIVIC's Avatar
I hit a curb going way ******* slower, but my wheel went all the way back against the fender and the top points out far. How much will it cost to repare? Nothing really looks damaged other than the fact that the wheel shouldn't be there. 1990 Honda Civic
Old Dec 10, 2012 | 03:27 PM
fcm's Avatar
fcm
Old Fart
Don't see a pic???
However I agree with most of the above, it has to be either the lower control arm or where it mounts to the frame rail, I also agree that the strut is most likely also bent. 94
wdissident
13
Aug 16, 2021 02:56 AM
Importn2oRacer
Mar 14, 2011 03:04 AM
followthadollar
Apr 27, 2010 08:32 PM
vtec25
Dec 30, 2007 04:20 PM
89dohcEF
Oct 11, 2003 08:20 PM
