Koni yellows with Eibach ERS - what length
thinking of Koni Yellows (already ordered) with Eibach ERS race springs with either 425F/375R or 400F/350R (its for a street car not a race car). how do i go about getting the koni adjustable spring perch for these to be coil-overs, or do i have to go GC
Modified by alwaysoverkill at 6:25 PM 10/31/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alwaysoverkill »</TD></TR><TR><TD CLASS="quote"> how do i go about getting the koni adjustable spring perch for these to be coil-overs, or do i have to go GC
you can't run ERS springs with out a coilover setup. They will not sit right. Most people go with 7 or 8 inch springs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch »</TD></TR><TR><TD CLASS="quote">
you can't run ERS springs with out a coilover setup. They will not sit right. Most people go with 7 or 8 inch springs.</TD></TR></TABLE>
What about the hyperco springs?
this may sound like a really stupid question, but Ground-control has their own upper spring perch so i don't need stock right? or does the ground-control still req stock spring perch (top hat)
i'm just going to go with ground-control with 400F/350R rates to go with a 22mm civic type r rear sway bar already installed (With beaks kit) but if i don't need the stock spring perch, i'll sell my old set-up fully assembled.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rancid_949 »</TD></TR><TR><TD CLASS="quote">
What about the hyperco springs?</TD></TR></TABLE>
no they wound the same as ERS springs,<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alwaysoverkill »</TD></TR><TR><TD CLASS="quote">this may sound like a really stupid question, but Ground-control has their own upper spring perch so i don't need stock right? or does the ground-control still req stock spring perch (top hat)
i'm just going to go with ground-control with 400F/350R rates to go with a 22mm civic type r rear sway bar already installed (With beaks kit) but if i don't need the stock spring perch, i'll sell my old set-up fully assembled.</TD></TR></TABLE>
as long as you perchase the new GC top hats then you wont need anything from your old setup.
le0ftw
Oct 17, 2007 02:01 PM
FOB
Mar 11, 2003 12:49 PM
