Intermidiate shaft problem?
Old Oct 31, 2005 | 04:45 PM
JFG Kevin's Avatar
Default Intermidiate shaft problem?
my intermidiate shaft and my driver side axle moves in and out when i spin the tire in the air. I'm not sure what's going on with that, any ideas?..Isn't the bracket on the intermiditate shft suppose to hold that shaft from moving up and down, in and out?..i know my axles are not broken cause there's no clicking when i turn. My axle nut has not moved from it's original place...need help ASAP...thx...
Old Nov 1, 2005 | 11:34 AM
JFG Kevin's Avatar
Default Re: Intermidiate shaft problem? (aznstyler119)
bump
Old Nov 1, 2005 | 03:58 PM
NJIN BUILDR's Avatar
http://www.hondaautomotivepart...82%29
This is a 2000 civic si b16,similar to most engines with a midshaft.
There is a circlip (#25) that holds it in place.My guess is the clip has failed and/or the bearing is toast.
Glenn
Old Nov 1, 2005 | 10:35 PM
JFG Kevin's Avatar
Default Re: Intermidiate shaft problem? (NJIN BUILDR)
hum...Maybe. i'll check that out..is there anyway of checkin that out? I mean after i pull out the intermiate shaft how do i check if it's broken or not...what signs do i look for..thx.
LeeMajors19082
Oct 3, 2016 05:30 AM
DTS
Oct 6, 2006 08:11 AM
Cheeech
20
Dec 22, 2005 05:55 PM
JFG Kevin
Nov 1, 2005 10:34 PM
