I think i overfilled my tranny fluid.. would this cause a leak?
Old Oct 31, 2005 | 04:18 PM
JDMlyfestyle's Avatar
Default I think i overfilled my tranny fluid.. would this cause a leak?
I changed my tranny fluid today. and i put in some Synchromesh. Now if i over filled it would it cause a slight leak?
Old Oct 31, 2005 | 04:21 PM
super_nguyen's Avatar
Default Re: I think i overfilled my tranny fluid.. would this cause a leak? (JDMlyfestyle)
if you over fill it, it will leak out slowly, might even make a little smoke. or so it says in my haynes manual for my b16 tranny.
Old Oct 31, 2005 | 04:24 PM
TurboEM1's Avatar
Default Re: I think i overfilled my tranny fluid.. would this cause a leak? (super_nguyen)
how would it smoke? would tranny fluid get into the combustion chamber???
Old Oct 31, 2005 | 04:25 PM
ok cause i didnt lay down a pan when i was filling up and the hose was the exact fit for the hole. and as soon as i pulled it ou fluid started pouring all over my floor.. so i hurried and threw the plug in and i took it for a drive and when i parked it there was a nickle sized puddle under the tranny after i parked it
Old Oct 31, 2005 | 04:34 PM
nocturnaldragon's Avatar
Default Re: (JDMlyfestyle)
that could also be from the oil you already dripped on the side of the trans. I don't think it will leak because the transmission is pressurized or anything it just splashes around on the gears and what not or there completely submerged.
Old Nov 1, 2005 | 03:59 PM
SicilianSpeed42's Avatar
im not sure what tranny you got in there, but on my 93 dx theres 2 holes, a filler hole and a drain hole. you fill it until fluid starts to run out of the filler hole. As far as smoke, i dont see that as a possibility considering we are talking about a tranny here.
sickofitall1113
May 16, 2007 01:57 PM
Sean DM
Honda Civic (2001 - 2005)
Sep 25, 2006 02:28 PM
roterx7
39
May 30, 2006 09:08 PM
eg92b16a2
Apr 25, 2006 01:26 PM
B2FiNiTY
Oct 30, 2002 05:50 AM
