obdo b16a?
Old Oct 31, 2005 | 03:49 PM
Honda Crx's Avatar
Default obdo b16a?
Will the stock motor mounts on THAT motor work in my 90 ef civic? I'm all that sure. Don't know if I should order the hasports ones which are better, but if I don't have too I don't want too.
Old Oct 31, 2005 | 03:52 PM
CRX Toad's Avatar
Default Re: obdo b16a? (Honda Crx)
You will have to cut and reweld to get stock mounts to work with your B16. I would get mounts from http://www.azracemachine.com instead of HaSport. In the end it is your choice.
Old Oct 31, 2005 | 03:57 PM
Honda Crx's Avatar
Default Re: obdo b16a? (CRX Toad)
cheaper than hasport... damn i was hoping to save some money with the mounts
Old Oct 31, 2005 | 05:48 PM
Craigp23usa's Avatar
HASport is a good mount. Remember though. since HASport is a racing/aftermarket mount it positions it about 2 in. back. You will need teg intermediate and axle. unless you were lucky enugh to get some Si-R ones. (Si-R) intermediate still a bit to long. FYI
Old Oct 31, 2005 | 07:38 PM
SomeDude56's Avatar
Default Re: (Craigp23usa)
while were on the topic r the axles included in say the hmotors b16 package for sir1s are those the axles you would use instead of tegs or would u still have to get 90-93 teg axles?
Old Oct 31, 2005 | 07:43 PM
EBP_Em1's Avatar
Default Re: (SomeDude56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SomeDude56 &raquo;</TD></TR><TR><TD CLASS="quote">while were on the topic r the axles included in say the hmotors b16 package for sir1s are those the axles you would use instead of tegs or would u still have to get 90-93 teg axles?</TD></TR></TABLE>
"B16A 88-91 (SiR I) Complete Change Over
Price: $ 1499.00 Plus shipping and handling.
Availability: In stock and ready to go
- Motor
- Cable Tranny (Y1, S1, J1)
- ECU (PR3, PW0)
- Axles with Half Shaft
- Shift Linkage*
- Stock Motor Mounts*
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Comes With All Sensors Needed
- LSD Tranny (Optional +$300)
Motors average 35,000 miles and come with a 100% start up warranty. All Sensors are guaranteed not broken and in working condition!
*Requires aftermarket parts for most applications. We can supply you with the hasport mount kit for $300 and the hasport linkage for $60.Prices only valid with purchase of a complete changeover. We can also supply you with 90-93 Integra steering knuckles and hubs for $50 if you need them. Also availabe is the Hasport Aluminum A/C bracket for $160 and the Hasport wiring sub-harness for EF civics that are either HF or Si models (not DX or STD) for $60. "
Straight from the horse's mouth (or should I say fingers?).
Old Oct 31, 2005 | 07:46 PM
sycamore
Guest
Posts: n/a
i got my mounts off ebay for 100 bones work great the motor sits a bit low but who cares..
Old Oct 31, 2005 | 07:51 PM
SomeDude56's Avatar
Default Re: (TaylorDA)
damnnnnn i always thought you still had to use new axles and half shaft,
thanks man. HMO it is.
Old Nov 1, 2005 | 05:11 AM
Honda Crx's Avatar
hmotors is it..
Old Nov 1, 2005 | 05:48 AM
Autoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">You will have to cut and reweld to get stock mounts to work with your B16. I would get mounts from http://www.azracemachine.com instead of HaSport. In the end it is your choice. </TD></TR></TABLE>
they make nice linkages too
Old Nov 7, 2005 | 05:43 PM
Default Re: obdo b16a? (Autoworks)
Some swaps go better than others and even though two diff people mihgt use the same crap. diff outcomes result. in my case with a b16 swap with hasport mounts, the si-r axles and intermediate should have worked. they didnt so i just got a teg intermediate. the picture below shows the diff and YES the SI-R axles Male ned drivers fits into the female spline end of intermediate.
Intermediate comparison: Teg (shorter) SI-r (Longer)
turbolshatch
Sep 5, 2003 12:14 PM
Magnaflow
Aug 15, 2003 07:25 AM
citrusdrop
May 4, 2003 01:25 PM
Rratedcivichatch
Jan 2, 2003 03:51 PM
Charlie Moua
Apr 10, 2002 04:02 PM
