Found 15x8's for less than $300 for all five wheels (spare included!)
I was able to find budget 15x8's. Cast aluminum, +25 offset, very cheap. The downside is they are 5x4.5" only. I will post pictures tonight, and maybe offer a prize to the first person who can guess what company makes them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superpilun »</TD></TR><TR><TD CLASS="quote">I was able to find budget 15x8's. Cast aluminum, +25 offset, very cheap. The downside is they are 5x4.5" only. I will post pictures tonight, and maybe offer a prize to the first person who can guess what company makes them.
Centerline
</TD></TR></TABLE>Centerline
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superpilun »</TD></TR><TR><TD CLASS="quote">Nope not Centerline, here's a big clue:
I'll post some pictures of them on the car soon.</TD></TR></TABLE>
hmm they don't exactly look light weight
Yeah ok fine, but if you're looking for a 15x8 for a few bills, you're obviously not shooting for pole position anyway. So the few extra pounds aren't that big of a deal. Heck someone was running steel 15x9's without problems. Anyway these are like 17lbs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superpilun »</TD></TR><TR><TD CLASS="quote">Yeah ok fine, but if you're looking for a 15x8 for a few bills, you're obviously not shooting for pole position anyway. So the few extra pounds aren't that big of a deal. Heck someone was running steel 15x9's without problems. Anyway these are like 17lbs.</TD></TR></TABLE>
at some point more weight has to negate the advantage of a wider wheel though. Will you be faster running heavy 15x8's than you would running much lighter 15x7's?
Heavy 15x8+ for cheap is nothing new:
http://www.diamondracingwheels.com
or
http://www.circleracing.com
or
Well, I think choosing the optimum tire size should take priority over wheel width. If you look at some popular offerings, the only size that gives decent footprint width without sacrificing gearing is 225/45-15. It's actually a bit shorter than a 205/50-15 so you get even better gearing with the 225/45. A wider tire obviously weighs more than a narrower tire but yet everyone is trying to run the widest they can. The same should apply to the wheel. It's not that much heavier and the wider tire with increased track width is more than enough to compensate for the increased unsprung weight within reason, so it should be a net gain in ultimate grip (can't say the same for bump steer though).
Yeah I looked at the wheels with the stamped steel faces but that design just doesn't provide any caliper clearance (I tried some from summitracing and had to return them). Even with these OEM 15x8 wheels I had to grind the caliper down a couple mm.
Ok fine so not many of you care. They're Jeep Wrangler Ravine wheels that I scored off ebay. It had the right width and offset and bolt pattern so I bought 'em!
Some photos... To my surprise I didn't have fender clearance problems, my guess is inadequate compression travel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superpilun »</TD></TR><TR><TD CLASS="quote">Ok fine so not many of you care. They're Jeep Wrangler Ravine wheels that I scored off ebay. It had the right width and offset and bolt pattern so I bought 'em!
Some photos... To my surprise I didn't have fender clearance problems, my guess is inadequate compression travel.</TD></TR></TABLE>
You had to grind a mm off of your caliper to get the wheels to fit?
Modified by Black R at 2:56 AM 1/4/2006
Some photos... To my surprise I didn't have fender clearance problems, my guess is inadequate compression travel.</TD></TR></TABLE>You had to grind a mm off of your caliper to get the wheels to fit?
SiB16A
Feb 27, 2007 09:51 PM
superpilun
13
Nov 26, 2005 10:18 PM
