Gsr swap help
Old Oct 31, 2005 | 01:25 PM
god.loves.ugly
Guest
Posts: n/a
Default Gsr swap help
01' ls looking to swap a gsr motor.
can I use the stock motor mounts?
can I use the ls tranny and axles?
I'm trying to do this on a budget.
any help would be good.
Old Oct 31, 2005 | 01:35 PM
mjc1055's Avatar
Default Re: Gsr swap help (xDantex)
Yes you can use stock motor mounts
Yes you can use LS axles/tranny, but I'd seriously think about ditching it to try to find a GSR/b16 tranny if I could, the tranny is half the reason the GSR is fun to drive.
Old Oct 31, 2005 | 01:42 PM
god.loves.ugly
Guest
Posts: n/a
Default Re: Gsr swap help (mjc1055)
yeah I think I will put the motor in sell my ls motor use that money to put toward the tranny then hopefully sell the ls tranny to ha ha. its going to be a slow process
Old Oct 31, 2005 | 01:44 PM
mjc1055's Avatar
I think you're going to be sorely disappointed with the motor alone, though. I'd think about picking up the GSR if you can get it for a good price, but waiting to put it in till you have the tranny.. otherwise you might just be left wondering why you dropped all that cash for a minimal difference.
If I were you though, I'd just save the money and instead of buying a GSR swap, boost it
Turbo LS > Stock GSR
Old Oct 31, 2005 | 01:48 PM
god.loves.ugly
Guest
Posts: n/a
so much more work goes into boosting like upgrading internals and stuff that I just don't want to deal with how much boost can a stock ls handle? ha ha
Old Oct 31, 2005 | 02:02 PM
mjc1055's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xDantex &raquo;</TD></TR><TR><TD CLASS="quote">so much more work goes into boosting like upgrading internals and stuff that I just don't want to deal with how much boost can a stock ls handle? ha ha </TD></TR></TABLE>
It all depends on the tune, but you can safely get anywhere from 200-250 horsepower, or maybe even more if you have a good tuner, all on stock internals. That's at the wheels, by the way. How much does a stock GSR make, again? Like 140ish? Not even really a comparison.
As far as how much psi the motor can handle, thats dependant on what turbo you're running, but most people generally run between 7-12 psi stock.
Old Oct 31, 2005 | 02:03 PM
god.loves.ugly
Guest
Posts: n/a
you have a point. turbo kit it is.
Old Oct 31, 2005 | 03:01 PM
god.loves.ugly
Guest
Posts: n/a
how about a turbo b16... maybe. there is way too many options.
Old Oct 31, 2005 | 03:52 PM
Vtec5150's Avatar
I just put in Some Je pistons in my gsr they are a 12.5 comp. and also ported and polished the head. I got it dynod and it only came back with 162 horses to the wheel. should I have more than that or is that ok?
Old Oct 31, 2005 | 04:35 PM
mjc1055's Avatar
Default Re: (Vtec5150)
Is that all you have done? Just p&p and the pistons? Is it even tuned? It seems pretty crazy to mee to be running that kind of compression without a better built head and not being tuned.. actually I take it back. If you don't get it tuned, you're going to blow it up.
162 isn't bad if that's all thats done to it.. I guess I've just never seen anybody start with a stock motor other than 12.5 compression..
Old Oct 31, 2005 | 04:53 PM
97CGPintegra's Avatar
xdantex, i suggest you just keep your current stock ls motor for turbo. b16 will just be more money that you could be spending to turbo parts instead. if you have a '01 ls integra you shouldn't have too many miles or problems turboing the car.
Old Oct 31, 2005 | 08:14 PM
Backk InTheDA's Avatar
I hate everything
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mjc1055 &raquo;</TD></TR><TR><TD CLASS="quote">Yes you can use stock motor mounts
Yes you can use LS axles/tranny, but I'd seriously think about ditching it to try to find a GSR/b16 tranny if I could, the tranny is half the reason the GSR is fun to drive.</TD></TR></TABLE>
BeRightBack
Jul 3, 2008 08:27 PM
Krucial_Ek9
Apr 11, 2008 09:25 PM
rotten_eg6
14
Apr 13, 2007 01:43 AM
B_1_8_hatch
May 5, 2003 02:25 PM
abs0lutexer0
Apr 30, 2003 11:10 PM
