DOHC ZC Power Steering Setup Qs
Old Oct 31, 2005 | 11:39 AM
Modern91Hatch's Avatar
Default DOHC ZC Power Steering Setup Qs
I've installed a DOHC ZC in my 89 CRX. I've put a power steering rack and cross member from a Power Steering civic. The PS bracket from a SOHC D-series won't fit. Can I use the PS Pump and bracket from the 88-89 Acura 1.6l?
Old Oct 31, 2005 | 07:59 PM
Default Re: DOHC ZC Power Steering Setup Qs (Modern91Hatch)
bump for Halloween!
Old Nov 3, 2005 | 02:54 PM
Bump
Old Nov 3, 2005 | 03:49 PM
TwztdSi's Avatar
I need to know the same thing......if anyone can help. Just put a dohc zc into an 89 hatch I bought. Anyone know anywhere online that sells cheap acura parts? No junkyard close to me as an 88-89 integra for me to get the bracket from.
Old Dec 22, 2005 | 01:22 PM
Default Re: DOHC ZC Power Steering Setup Qs (TwztdSi)
I've figured it out.
-The OBD0 SOHC D-series use one type of bracket.
-The OBD0 88-89 Acura Integra have a completly different PS location, meaning differnet mounts.
-The OBD0 DOHC JDM ZC from the 90-91 CRX Si has yet another different PS mounting. It's location is simialar to the SOHC D
You will need the CRX Si ZC PS brackets in order to fit the PS pump like stock. Nothing else I've found will work. I believe the PS pumps between the CRX Si ZC and SOHC D are the same.
Old Dec 22, 2005 | 01:40 PM
CRX Toad's Avatar
That is good info. Why would you want PS on CRX?
Manual > PS
Old Dec 30, 2005 | 10:23 PM
Default Re: DOHC ZC Power Steering Setup Qs (CRX Toad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">That is good info. Why would you want PS on CRX?
Manual &gt; PS</TD></TR></TABLE>
I doesn't weight much and doesn't take much hp and most of all... my wife will be driving it as well.
Old Dec 31, 2005 | 03:28 AM
Hcivic88's Avatar
if it helps you out at all, my dohc came with power steering and A/C, although i ended up removing both and am willing to sell whatever brackets you may need.. bad part though is that im in canada so shipping may be a bitch.
Old Sep 4, 2012 | 10:19 AM
galbal's Avatar
pls post some pictures of the installed PS kit! ty
Old Sep 4, 2012 | 12:12 PM
hatchbklvr's Avatar
the zc dohc engine is unique n in order to keep or have power steering u need the bracket n pump n the lines from the zc dohc motor odb0 or obd1 both r the same
thisiskev
May 16, 2009 08:50 PM
thisiskev
May 12, 2009 01:28 PM
spikehead221
Aug 29, 2008 09:51 PM
topdawg57
Dec 30, 2003 10:05 AM
